2004 Lincoln Navigator Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 lincoln navigator suspension went out, vehicle is sitting low on rear tire
Anonymous
Level 2:
  • Expert 49 Answers
  • Posted on Jun 28, 2009
Anonymous
Expert
Level 2:
Answers
49
Questions
0
Helped
20820
Points
138
Hopefully just needs to be reset, those air susp r expensive. Some susp come with a switch to turn on and off could be on the left or right rear back look for it turn off then on if that does not work, disconnect p bat terminal for 5 min then reconnect. Listen for suspension should make some noise.
Air suspension rear vehicle
INSIDE THE WHEEL OPENING TUCKED INTO THE FRAME WHERE THE REARWARD CRADLE IS LOCATED BESIDE THE SUSPENSION AIRBAG
2answers
What size coil springs for 2001 lincoln navigator rear supension
That is not a question you ask on the internet,
& no one has any diagrams, unless they own the
same vehicle & have purchased factory manuals
You ask a dealer by giving the parts dept your
VIN #
If your converting from air to conventional suspension,
then you ask the parts suppliers that sell the new parts
your going to use to replace the air shocks/struts
1helpful
2answers
The rear end of my Lincoln Navigator will not raise.
could just be a seal on the air line itself, or possibly a whole in the line or one of th eleveling air bags. gong thru the water should'nt have any effect on it,unfortunately these are just like any other part, or seal they just eventually wear out.
Does anyone have diagrams for the rear suspension for a 2007 Lincoln Navigator ?? I'm trying to troubleshoot a problem with my Navigator; the rear of the truck is almost touching the...
don live in the real world, that suspension is never going to work right again. you are going to spend a ton of money, and no matter what you do something else will go wrong. big mercs, lincolns, BMW, caddies, land rovers, etc all sit in the same saggy swamp. there are still thousands of collapsed Peugeots sitting in barns since the 1970s across the land waiting for a real suspension fix.
take a long look at www.strutmasters.com and consider junking the air or hydraulic suspension system and trading up to a real one with springs and shocks.
99 lincoln naviagator that bounces bad and sits low in rear<
your truck comes with suspension airbag for a smooth right..all lincoln naviagator come with it..if your take it the shop and they forget to disable that before they lift it up..most likely they blown the airbag for your suspension...those air suspension are rear spring for your truck
1helpful
Rear suspension fell
it most likely blew a line going to the rear leveling valve to leval out the truck i would start there and then check the bags and the valve it self.
1helpful
2001 Lincoln Navigator Air Suspension
the auto leveling is standard on the navigator.
first you have to understan that the auto leveling system is on front and rear of these trucks.
one way to tell is do you hear the pump running and do you have air in the front bags. and if you do you need a rear level sensor.
later paul
16helpful
3answers
do you have a auto leveling system?
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
