The fuse box is located below and to the left of steering wheel by the brake pedal remove cover use the fuse puller attached inside cover located fog lamp fuse should be number 9 , 15 amps replace with same amps . car should be off. [ if can't find fog lamp fuse it might be unlabled pull the unlable ones check if the are blown wire would be broken.
SOURCE: How to change the fog light bulb on a lincoln ls
get under the car and the fog lamps will be on the corners of each side. all you do is twist the electrical connector to the right and it will come out to install one re connect the new bulb and line up the connector and turn to the left to lock it in place
SOURCE: 1998 Lincoln Navigator, headlights and fog lights don't come on. Only my parking lights comes on.
check your relay
