1998 Volkswagen Beetle Logo
Posted on Jun 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1970 vw bug mix fueal and engine oil - 1998 Volkswagen Beetle
Anonymous
Level 3:
President:
  • Master 2,559 Answers
  • Posted on Jun 27, 2009
Anonymous
Master
Level 3:
President:
Answers
2559
Questions
Helped
1213630
Points
9283
There is no mixed fuel in it,It is a 4 stroke not a 2 stroke,It uses regular gas,Also,The oil can be any brand and should be 10w 30 or 10w 40 .
Why does my car stereo begin to display superfast and tweek and flash when I am driving higher RPM's in a 1970 VW Bug. It is over volting the radio right?
check your charging system with a DMM it should read about 12.5v when engine not running and 13 to 14v when running any figure above that is definitely an over charge and could lead to various malfunctions on the vehicle.
1970 vw bug
there should be a set screw but if not and you see a little slot at the bottom of the mirror stick a very small screw driver in to press a tang inside and push the mirror up the little metal piece will stay on the window
1helpful
May have radiator fluid in oil 2001 vw beetle
An oil leak mixing with coolant is an internal leak, which is usually the result of a faulty or damaged head gasket, or cracked head. This is a major repair job, because the entire top of the engine has to be removed to do the repair. You can't see the leak because it's inside the engine, not outside of it. White smoke (steam) should be coming out of the exhaust pipe if this is true.
3answers
What kind of oil is best for my bug. It has 114 thousand miles on it
For VW gasoline or diesel engines it is recommended to use 5w-30 SYNTHETIC, but needs to meet the VW standard 50200-50500 (most if not all Mobile 1 oils do).
2answers
What engine oil should i use in my 1970 kombi camper
Any 5W30 will work fine, however because the oil coolers in 1970 and pre 70 VW were so marginal it is a good idea to put a full flow oil filter on and if you really want to do it a service you should consider a remote cooler or a post 70 VW dog house cooler that was larger and added to your oil capacity by about 1.5 qts and you can extend your oil change to 3000 mi. I am an avid Amsoil fan for proven reasons... I have a hard working F-350 power stroke diesel with 240,000 miles on it and still as strong as new thanks to Amsoil 100% synthetic. One thing about synthetics that will help your 70 is that they tend to make your engine run cooler, but be warned if you have an oil consumption condition now it will be aggravated by synthetics so in that case stick with a good quality name brand Dino oil like Shell or Esso etc.
4helpful
Engine speed sensor location, 2001 vw bug
The Engine speed sender is located on the front of the engine block at the level of the crankshaft near to the gearbox bell housing.
I bought used 2006 VW Passat with 52,000 miles. Oil level low and black color.. after changed oil find oil in coolant tank. engine runs ok... check engine on... any advice?
head gasket leaking. does the oil cap look like pudding stuck inside of it? if so that was caused by the tow fluids mixing together in the engine
3helpful
1976 vw 1600 need engine tq specs
1970 - 1979 Engine Torque Wrench settings LB FT Nm mkg Connecting rod nut 22 - 25 29.8 - 33.8 3.0 - 3.3 Crankcase screws M8 (halves) 14 19.0 2.0 Crankcase nuts M12 (halves) 18 24.4 2.5 Cylinder head nuts (M10) 23 31.2 3.2 Cylinder head nuts (M8) 18 24.4 2.5 Rocker shaft to Cylinder head nuts 14 - 18 19.0 - 24.4 2.0 - 2.5 Oil Pump to crankcase nut 14 19.0 2.0 Oil drain plug 25 33.8 3.5 Oil strainer cover nuts 5 6.7 0.7 Flywheel to crankcase bolt 253 343.0 35.0 Clutch to Flywheel bolt 18 24.4 2.5 Spark Plugs 25 33.8 3.5 Engine to Transmission nut 22 - 29 29.8 - 39.3 3.0 - 4.0 Converter to Drive plate bolt 81 109.8 2.5 Generator Pulley 40 - 47 54.2 - 63.7 5.5 - 6.5 Special nut for Fan (M12) 40 - 47 54.2 - 63.7 5.5 - 6.5 Crankshaft Pulley bolt 29 - 36 39.3 - 48.8 4.0 - 5.0
2helpful
1970 vw bug-idles fine, stalls when trying to drive it..
You either have a carb or exhaust issue. Here is a link that will help you out A LOT!
http://www.vw-resource.com/index.html
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
