The boom ladder wont go up an down on my fire rescue tonka truck but the moter goes how do i fix this please
Make sure you take pictures and mark what screws go where. (very important) ! After you take it all apart, the motor is housed inside the plastic case. This motor makes the ladder go up and down. There are 2 gears on the outside of the case. 1 large gear and 1 smaller gear. If you look closely at the smaller gear you will see that the gear is split. The split will appear in the valley between 2 gear teeth. Because of the split, the shaft end will spin and the small gear may spin for a second, but the gear will stop spinning. (small gear is toast) You won't notice it unless you get really close ! Good luck finding that gear. I haven't found that gear yet. Hope this helps !
