Your memory card has a switch that prevents its contents from being erased or not allow new pictures to be saved onto it. Change the position of the switch to unprotected.
If the card is a Secure Digital (SD), SDHC or SDXC there is a write protect switch on the card which can be slid up and down. Up means it can be written too, down means the card cannot be written too. If the card is in the position where you can write to it but the camera is saying the card is still protected it maybe a faulty card or the camera may have a fault.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Do you mean "write" protection instead of "white protection"? If so, look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
It means that your memory card has been protected from writes, preserving its contents. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Than means you can't erase the data on that card without a password, or administative controls. Someone somehow had requested to make this card protected.
It means the card has been protected from writing, preserving its current contents.
Take the memory card out of the camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
That means that your SD card (or whichever memory card you use) is write protected and you cannot edit the card's content in any way.
Take your memory card out of the camera and plug it into your computer. There should be a place for you to change the memory card's protections that way. Sometimes, as with USB drives, there might be a small sliding lock physically located on the card which will also write protect the device.
