This gun is about 30 yrs old. Still shoots strong. There are 2 holes on top of front barrel. 1 for sight & I assume 1 for a cover where bb's are loaded.
SOURCE: Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
SOURCE: where can I buy repair parts for daisy 880? also
Daisy.com should have everything especially a owners manual with parts list. They don't fool around with safety.
