Cars & Trucks Logo
Dennis Posted on May 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine code 2181 enhanced dtc for 2004 vw beetle 2.0 turbo
frederik troost
Level 2:
  • Expert 67 Answers
  • Posted on May 14, 2014
frederik troost
Expert
Level 2:
Answers
67
Questions
Helped
17650
Points
108
It is problem with cooling,check if two fans are running with airco on,
if yes,check codes again,look at freeze frame data,
look for temp and time indication,with engine temp and rpm,
if temp is not high,check fan motors resistance,
one broken with ohm too high?
2answers
Where is the crankshaft sensor located on a 2013 VW beetle 2.0 TSI turbo engine?
all cars it is 1 of 3 places off the crank shaft
front ,center or rear,. some even are no the tranny flex plate.(crude reluctor)
the water beetle,
no country told. usa CAR IF YES WHY NOT SAY SO , WE USE JUST ONE 2.0l
NO ENGINE TOLD LOTS OF 2.0.
A5 BEETLE 2012-2013 TSI 2.0L??????
2013 VW beetle 2.0 TSI turbo engine. 16 VALVE?
THE EA888????? 3 generations of TSI MADE, GEN 2 IS 2008
197 bhp 2.0-litre turbo petrol engine
A5 BEETLE
VW OUCH
CALLS IT AND ENGINE SPEED SENSOR. SURE BUT IS NEVER IT'S PRIMARY GOAL EVER (rpm) THE GOAL IS EXACT SPARK AND INJECTION TIMING
NOT SPEED,
USA SHOP MANUAL SAYS.
Engine Speed Sensor G28 <<< BINGO REAL NAME FOUND, HARD TO DO.2.0l
  1. On the front lower left side of the cylinder block, next to the oil separator. Refer to (see more...)
  2. Removing and installing. Refer to Engine Speed Sensor G28, Removing and Installing.
PULL ENGINE COVER
Open the air guide pipe hose clamp 2
Disconnect the connector arrow.?Remove the noise insulation. Refer to see Noise Insulation; Overview - Noise Insulation.
?Remove the bolts 1 and 4 and remove the air guide hose downward from the Throttle Valve Control Module J338.
?Remove the air guide hose 1 from the charge air cooler and remove the air guide pipe downward.
Disconnect the connector 1 from the Engine Speed Sensor G28.?Remove the Engine Speed Sensor G28 bolt.
G28 IS SUPER SECRET CODE FOR CKP. (USA NAMES)
2004 vw beetle 2.0 turbo engine code P0411 any ideas
P0411 Secondary Air Injection System Incorrect Flow Detected
Read more at: http://www.obd-codes.com/p0411
Car will start but shuts off immediately - 2002 volkswagen beetle
I have a 2004 vw Beetle 2 L engine that had the same problem.
After taking it to two mechanics finally diagnosed you need to start with replacing the Air Flow Meter. Fortunately for me this was the right fix.
It is an expensive part ($150-$200) that can not be returned.
You can also try a junk yard, you pull it and they run $40-$75.
That is what i did and it worked.
Good Luck.
2helpful
2181 code ecl on radiator fans dead
CODE P2181 COOLING SYSTEM PERFORMANCE MALFUNCTION CONDITIONS - ECT SENSOR HAS FAILED. 2.0L ENGINE ECT LOCATION IS ON THE UPPER RADIATOR HOSE CONNECTION AT THE REAR OF THE CYLINDER HEAD. 2.5L ENGINE ECT IS ON THE UPPER RADIATOR HOSE CONNECTION ON THE CYLINDER HEAD ALSO.CHECK COOLING FAN FUSE AND RELAYS
1helpful
Vw beetle 2002 2.0 115hp
Had the same issue. I replaced one of the fuses in the little case on top of the engine. Check the fuse diagram in the manual, locate the one for a/c. The fuses are color coded by amps, just buy the right color and push into place. (I did this after verifying my coolant levels were normal)
1helpful
My 2002 vw turbo beetle cut off while driving.
this is not good; you probably ran the turbo bearings dry and they have seized try to loosen the turbo by removing it breaking it loose and lubricating the bearings if they are still good or, find another one at the junkyard
1helpful
Code # on 2003vw beetle
the p2128 code is a Performance Malfunction in Cooling System error and comes from a faulty ECT sensor, radiator issues or a bad thermostat.
11helpful
3answers
2002 VW Beetle EPC light on
where is the break light switch on a vw bettle
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
