You could look at the instructions first if any .but if you follow these simple steps you'll have them in stalled. First make sure the product
is correct for your application, if so we may begin, remove all hardware from box. Here we go you'll have 4 brackets, (should be the same)take 2 of the brackets and mount them to the tubing ends, there should bolts/washers that were in the kit. Tighten(but loose enough were it a bit flex able) these washers/bolts, and make sure that the bracket is facing (the hole of the bracket is facing upward) to the brackets and tubing and do this with the other one. Put of to the side now, now we will start with the truck now,loking under the truck locate the body mounts of the truck(these are a bolt with a large washer one them 1 of them is located about the beginning of the front door and the other is located after the rear door) unbolt these
two bolts,remove and clean bolts remember you must also remove the large rubber mount.Now take the tube and mount and install them where you took out the bolts earlier from the body.tight all bolts and look at everything and make sure that everthing is to your liking.
You are finished after installing the other side. your done enjoy.
