Cameras Logo
A
Anonymous Posted on May 02, 2014
WHAT IS IN SYNCHRONISED MONITOR MODE - Ricoh Cameras
1helpful
When i connect nokia 2690 to pc in data storage mode it is connected but when i try to connect in pc suit mode vo connect hi nahi hota hai
try to synchronise ur mobile with pc. for synchronising do this..
1.connect ur mobile to pc with data cable
2.then switch off ur mobile...
3.Now press switch ON button for some second(don't start ur mobile)
4.After tht ur mobile automatically synchronise with ur pc now start ur mobile nd try to connect.
Nov 15, 2011 • Cell Phones
I want to connat have I tect my mobilephone by blue tooth with my PC. Who do? Thanks for answer.
If your PC is NOT already Bluetooth enabled, you will need to purchase a USB Bluetooth Dongle
If your PC is already Bluetooth enabled,
On your phone, turn on the Bluetooth wireless feature
1. In Menu mode, select Applications ? Bluetooth.
2. Select the circle in the centre to turn on the Bluetooth wireless feature.
3. To allow other devices to locate your phone, select Settings ? On under My phone's
visibility ? a visibility option ? Save.
If you selected Custom, set duration that your phone is visible.
4. Select Save
Synchronise data
Learn to synchronise contacts, calendar, tasks, and
memos with the web server you have specified.
Create a synchronisation profile
1. In Menu mode, select Applications ? Synchronise.
2. Press and specify profile parameters (Tell it what program -Outlook- and what data -contacts - email - calendar - you want to sync).
3. When you are finished, press .Start synchronisation
2. Select a synchronisation profile.
3. Press to start synchronisation with the web server you have specified.
That should more or less do it. Let me know if you need more information.
Central locking not working on 2002 ford focus changed battery in fob cant find fuse 63
The key and car might need re-synchronising after changing the battery or pressing the buttons too many times when out of range.
Put the key in the ignition and turn the key to position 2 and back four times within 6 seconds.
After a beep the car is in programming mode for the next 10 seconds.
Press any button on the remote fob to synchronising.
Can this be used as a monitor for a computer?
Hello
Sorry. The answer is you can't. Computers output comes as VGA [Video Graphic Arrey],or AGP [Advanced Graphic Protocol]; and it is not directly compactable with TV inputs. The computer outputs, Red_Green_blue and Horizontal and Vertical synchronisation signals seperatly through one VGA cable which goes into the monitor and there they gets processed and you see the image on computer monitor. Monitors are equipped with such circuits to process the same, whereas in the TVs there are not. Your TV is equiped with S-video connection and not have a VGA input connection.
You must buy a VGA to RGB converter for this purpose. It can be bought from the electronic market, and will have instructions and remote control of its own to control it. You must give the computers signal [VGA], to the input of that converter,with a [VGA to VGA] cable and from which the converter outputs R_G_B [Red_Green_Blue] along with an other output contains synchronisation signal, as described earlier, and will have directions in its manual where should it to be connected. Different converters have different confugurations for this connection, and it will be described in its manual. Ok.
I want to copy all the contacts from Nokia 6060 to my pc and then copy to a new Nokia mobile. How do i do this?
dear sir,
kindly connect your mobile to p,c via p.c suite provided with along the phone.....
install the cd given in the box in your p.c and then connect your nokia mobile to p.c in phone mode and not in usb mode................
then you can synchronise all of ur messages,contacts,pic,videos to ur p.c
from p.c you can synchronise to ur mobile memory and later you can copy from phone memory to sim memory.....
thank you...take care
Why do I have to synchronise my wii fit every time I try to use it. The instructions state that with standard mode synchronisation the wii fit settings should be maintained even when the console has been...
you should maintain the proper things even when the console has been turned off.........
use repair guide to get clear about it , it can useful for your future to fix your problems....
click here to download repair guide............................
I would like to transfer photo from my w380 to the desk top to start a photo album
To synchronise/data transfer your phone using PC Suite:
Connect the USB cable to the computer and the phone.
In the phone: When you attach the USB cable to the phone, a USB connection window appears; select Phone mode.
Start the Sony Ericsson PC Suite.
In the computer: The first time you connect your phone to the computer, you must identify and name the phone. Wait for the drivers to be installed (this is done automatically).
In the computer: Select Synchronisation, and select your items to synchronise.
To start the synchronisation, click the Start sync button.
Cannot delete the "E" signe even though synchronisation was OK
it is the "E" for eastern time mode. in world time mode switch to pacific time for a second and see if it changes to a "P". if so this is what the "E" is for. hope this helps:)
1helpful
2answers
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Caplio R40 no image displayed ie blank screen
Send it back -if under warranty they will send you another.
Top Ricoh Cameras Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Tony Parsons
Tony Parsons
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
