Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
