Any one got the latest key
Subject: Star View 3 The Box Super when channels discappear ;o)
Hiya this is what I did & hopefully it'll work for U too -
1) Deleted all th channels & reset 'factory settings' by entering the code 0000, turned th box off waited a couple of minutes & turned it back on !!!
2) You may have to redownload channels so reconnect yr box to the computer & follow the link below (But try without doing this & goto stage 3) first & please let me kno if that works :-
http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess )
& press download !!!
3) ReConnect & Turn box back on; goto menu & press 1570 to get into the CASS SYSTEM & turn EMU on
Reinstall channels & voila
From
the main menu choose "Parental Controls;" it's option six.
Choose
the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK
button on the remote, scroll through until the TV-MA rating appears. Press the
right arrow button to move the highlight over to the "Status" field
and toggle to "View." Press the OK button. This will set the
age-based ratings to Mature.
From
the Parental Controls menu, select the second option, V-Chip Movie Ratings
Limit and change the rating to TV_MA and the "Status" to
"View."
From
the Parental Controls menu select the third option, V-Chip Unrated Program
Block and select item one, which will be "View."
Select
the fourth option, which is "Channel Block." Highlight the Channel
field and using the channel up and down buttons, go through and check they are
all set to 'View." Any set to "Block" will need to be toggled
back to View.
Lock the controls to activate the changes using item six on the
"Parental Controls" menu.
Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there or make a search by typing in the brand name of the device in
the "Search Box", at the top right of the display window
