Toro 250-06-04 1 in. FPT Electric Valve with Flow Control Logo
D
David Johnson Posted on Apr 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toro 240-06-04 which is almost identical to the 250. My sprinkler system on the number one valve quit working. I thought maybe it might be a solenoid, so I replaced that and it still didn't w
Is there a kit that I can buy to rebuild this valve?
Gregory Heald
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 71 Answers
  • Posted on Apr 24, 2014
Gregory Heald
Expert
Level 2:
New Friend:
Cheetah:
Answers
71
Questions
0
Helped
41043
Points
100
Connect the wire form a working zone to the valve to zone 1. If the zone comes on you have short in the wire for zone 1. You can confirm this by connecting it to the valve that was working and it probably will not. If you have a spare wire connect it to zone 1 and in pin 1 at
the timer.
If valve still does not open and you replaced the solenoid (which is rarely the problem) the hydraulics are probably worn out in the valve. Purchase the same valve and switch out everything accept the valve body itself essentially rebuilding the valve.
Bad wire, no spare and you want to avoid running a new stretch. Merge this zone with a similar one by connecting both valves to 1 wire. If the pressure is good they should all work as 1 zone. Otherwise you will have to run a new stretch.
How to adjust a toro mini sprinkler
Get your model number than google model number. They should have a set of directions to adjust everything from nozzle to the rotation of sprinkler
Jul 26, 2015 • Garden
System quit watering. Tried man/adv and won't energize sprinkler valves. I can operate sprinkler valves manually. Tried unplugging power source to reset. Any suggestions?
Most sprinkler valves run on electricity from the timer. If the time doesn't send electricity out, the valves don't open. If an animal has chewed through a wire, that valve won't open.
You can take a meter and check the voltage on the wire at the timer. If nothing, replace timer.
If you get correct voltage at timer, measure at valve. if voltage good there, replace valve.
Toro instructions
Follow the instructions from Toro.
Toro jar top valve quit working
When I work on a valve in the field we usually just leave the valve body in place and change out the parts from a new unit. As long as the valve body is intact as you have described this should remedy whatever problem you are having. Make certain all wire connections are good and that you are getting 24 - 28 volts to the valve selenoid when the timer has selected that station.
1helpful
2answers
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Toro Visiion Sprinkler Controller Troubleshooting
There are two Toro timer manuals posted:
Copy following links, for ez word search for each manual:
http://waterheatertimer.org/pdf/Toro-53794_UserGuide.pdf
http://waterheatertimer.org/Toro-53794_UserGuide.pdf
http://www.toro.com/en-us/homeowner/do-it-yourself-irrigation/timers/Pages/default.aspx
The timer can be reset to factory defaults by 'clearing program memory' following steps in manual.
Warranty period is 1 year protection against defects in workmanship, which is standard for timers from Woods to Intermatic to GE etc.
If the display is not working, and zone does not show, then that implies internal defect, or lack of power. Resetting timer might repair problem.
The timer has electro-magnetic relays, and not an internal solenoid.
The timer turns ON or turns OFF electric power to the water valves.
Water valves have solenoids that open and close when power from timer arrives at each zone.
The solenoid can make the sound you describe, but the timer relays with make small click sound as the electromagnetic relay opens and closes.
In addition to resetting timer to factory defaults, and then reprogramming you might try changing wires to different terminals.
Also the timer works on 24Volt AC transformer that plugs into outlet. It is possible to get display errors on timers when voltage is incorrect, or outlet and transformer are not connected well. Test outlet with circuit analyzer. Change outlet because outdoor outlets get corroded. Clean blades on transformer plug.
Power surge and other events can damage timers. Nearby lightning strike. Power outage causes surge when power resumes.
There is 24-hour backup battery, but the battery does not appear to be replaceable type and instead is rechargeable or capacitor type backup. So the battery is probably not the problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a Toro Monitor II (pin type, model #:172-06-11) yard sprinkler system. My wife and I bought this house about a year ago (foreclosure) and I am just now getting some time to look at the sprinkler...
Michael,
Two possibilities, one, the heads have valves in the bottom of them, and they are controlled my the water pressure in the tubing. You should have one valve, or possibly your meter, that turns the system on, but thats it for valves. The second possiblity, is hydraulic valves. The tubing from your controller goes to valves in your lawn that are controlled hydraulically. In both cases, as long as the tubing is pressurized, no water flows. Once your controller stops the flow of water to that particular tube, water flows.
Either way, if you have that controller, you don't have electric valves. Hope this helps.
Sep 19, 2010 • Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
