Took out the motor to clean out and did not mark the wires. I need help with a good wiring diagram.
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Oreck Orbiter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618779&thid=681757
Oreck Orbiter
Posted by eccott on Jun 18, 2008
Hi could you e-mail me a wiring diagram for the Oreck Orbiter please? I need to replace the mains cable & the cable to the motor. Thank you, Helen Eccott.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Orbiter Floor Machines ORB-500… you can contact the customer service line / tech support @ the Oreck Factory that I will list below for you and they will be happy to help or assist you in the wiring diagram, please include the model # and serial # with your request. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
SOURCE: XL2525 changing motor
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=723450
Posted by geoffjackie on Jun 30, 2008
Please forward the wiring instructions for changing the motor in my Oreck XL 2525
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can contact the Oreck factory for the wiring instructions but you need to give them the model # and the serial # if needed and I will supply you with the Oreck website and the cust serv phone # listed below. Also, you can check the owner’s manual and sometimes there is a schematic that shows you if information you need for changing the motor. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
