2002 Ford Explorer Logo
Veronica Ashler-brown Posted on Apr 11, 2014
Where are the fuse locations for 2002 explore power seats
Fuse location for power seats where are they located
DOCHOLLIDAYDDS
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 36 Answers
  • Posted on Dec 30, 2014
DOCHOLLIDAYDDS
Contributor
Level 1:
New Friend:
Cheetah:
Answers
36
Questions
Helped
13567
Points
70
Look under the dash left side panel for fuse panel access.
Also look in owner manual for fuse position/location assignment on fuse panel.
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Mar 12, 2009
SOURCE: All power windows stopped working 2003 explorer
Look under the hood. And use a test light to check each and every fuse with the Key switched on
jagjeffery
Jeffery Lewis
  • 329 Answers
  • Posted on Jun 01, 2009
SOURCE: ABS fuse locations
There are a total of 5 fuses for brake and abs functions 3 in central fuse box on the drivers side inside truck fuse #9 - 7.5 amp fuse #10 - 10 amp and fuse #11 - 7.5 amp then there are 2 big fuses under the hood in the main battery fuse box next to the battery fuse # 6 - 50 amp and fuse # 28 - 30 amp
Anonymous
  • 520 Answers
  • Posted on Jun 12, 2009
SOURCE: where is the horn located on a 1998 ford explorer
The horn is usually between the radiator and grill Assembly. The fuse is in fuse panel under the dash on the drivers side. Look at the lid and it shows the fuse placement and there use.
Anonymous
  • 1297 Answers
  • Posted on Apr 04, 2010
SOURCE: What is the fuse location for the power windows
for early production models
bjb (battery junction box) fuse #6
cjb (central junction box) fuse #17
for late production models
bjb (battery junction box) fuse #47
bjb (battery junction box) fuse #2
mecanica03
ROBERT GARCIA
  • 926 Answers
  • Posted on Sep 06, 2010
SOURCE: 2002 ford explorer fuse box
under hood driver side
Where is the power seat fuse located on a 2002 eddie bauer explore
your fuse should be inside the car in fuse box left of the steering wheel on dash ,so open door and look there and you should see a lid that says fuse on it ,if you do not see it in there it is under the hood on back driver side of hood its a black box looking thing that also says fuses on it with a plastic screw on it take off and this one is main fuses for your explorer .good luck
2helpful
WHAT IS THE FUSE LOCATION FOR THE POWER SEATS
Hi there:
Just two locations there:
Passenger compartment fuse panel
The fuse panel is located on the left hand side of the instrument panel facing the drivers side door.
osition 18 25A - Drivers Unlock Relay, All Unlock Relay, All Lock Relay, Power Seats
Power Distribution box
The power distribution box is located in the engine compartment.
Position 4 30A - Power Windows, Power Moon Roof, Power Seat
Hope this helps, also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
What do fuses 27&28 go to
Hi Fred:
According with the 2002 Explorer Owner Guide this fuses are located in passenger compartment fuse panel, located below instrument panel on drivers side...
Where is the blower motor relay in the fuse panel in a 2002 ford explorer
The relay is located in the fuse panel (power distribution box) located in the engine comaprtment. Below is a picture of the location of that panel and a diagram of the fuses and relays. The blower motor relay is the one located in the number 55 position. This should be in your owners manual if you have one. If you don't and would like a copy, you can email me at [email protected] with your make, model and year and I will be happy to email you a copy. I hope this helps and good luck.
2004 f350 4x4 6.0 diesel electrical problems
Locate the fuse box under the dash panel. Pull the fuses one at a time and inspect. They are very hard to judge if the fuse(s) are blown unless you pull them out to inspect.
3helpful
2answers
Which fuse on the fuse panel is the one for the power windows i lost the manual
I know thta, for a 2002 Ford Explorer, the 30 amp circuit breaker in location #62 of the power distribution box in the engine compartment is the power window circuit breaker. (unfortunately in the 2002 owner's manuals it is labelled accessory delay ) later years are labelled as the power window circuit breaker.
Hope helped with this. Remember rated this help, good luck.
3helpful
Which is the power window fuse on a 1997 ford explorer
On your 1997 Ford Explorer, in the power distribution box in the
engine compartment, in location # 4 there is a 30 amp maxi-fuse for
the power windows, power moonroof, and power seat.
DISCONNECT YOUR NEGATIVE BATTERY CABLE - PD BOX IS 'LIVE"
also in the fuse panel on the end of the dash, visible with driver's
door open there is a 7.5 amp fuse in location # 12 for the power
window relay, washer pump relay.
1helpful
Where are the fuse,s locater in a ford explorer 2002
The fuse panel is located below the
instrument panel on the driver’s
side
Power distribution Maxi Fuse box
The power distribution box contains
high-current fuses that protect your
vehicle’s main electrical systems
from overloads
Fuse location
There is not a fuse listed for heated seats but fuse 16 is for heated mirrors and fuse 11 is power seats. i'm guessing one of those should also control the heated seats.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
