SOURCE: install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
you have the memmory wire which is usually the yellow connected to the wrong wire it should go to a straight power red should go to accessory power now you should have wire harness basically its colors match to match the colors easy if colors dont match colors you messed up now the other thing is there is about 3 fuses from sterio to battery sometimes 2; on the back of radio and in the fuse box sometimes someone just adds the 3rd to the power wire in back check fuses if hooked up right simple check take ground power and the yellow memmory take sterio to battery with fuses on all 3 hook direct to battery nothing else if sterio powers up you know you have right wires if it doesnt power up you blew it
SOURCE: dehp5800mp wire harness
orange /white wire is power antenna wire i think.is your setup working????????.let me know the status..
SOURCE: I NEED A WIRE HARNESS FOR A PIONEER DEH-P6500, IS
try pacparts.com. any good car audio store should probably have it
also.
SOURCE: I need diagram wiring from 1994 Honda accord to
Hello my name is Israel. The following diagrams should be able to help you out. The first is for the honda and the second for the stereo. Good Luck.
Constant 12V+
Blue/White
Switched 12V+
Yellow/Red
Ground
Black
Illumination
Red/Black
Dimmer
n/a
Antenna Trigger
Yellow/White
Antenna
Left Rear
Front Speakers
6 1/2" Doors
Left Front (+)
Blue/Green
Left Front (-)
Gray/Black
Right Front (+)
Red/Green
Right Front (-)
Brown/Black
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Blue/Yellow
Left Rear (-)
Gray/White
Right Rear (+)
Red/Yellow
Right Rear (-)
Brown/White
Connect each wire yourself if your were unable to obtain a wiring harness to install your car stereo.
Connect the positive wire from each speaker to the positive connector on the back of the stereo first. Then connect the negative wire from each speaker to the negative connector on the back of the stereo. If there is only one wire coming from the speakers, the speakers are grounded at the chassis. In this case you will need to install new speaker wiring.
Connect the ground (-/black) wire of the stereo to a screw or bolt near where the radio is mounted in the dash. Make sure the wire is attached to metal, not plastic or fiberglass.
Connect the 12 constant and ignition power wires (both +/red) to the new stereo. Refer to your stereo's installation manual to make sure these go to the correct places.
