My mazda 323 b6 injecters are firering at the same time anf the cars does not start
Listen for the fuel pump to turn on with the key ON. Do you hear it buzz on for a couple of seconds, and then shut off? If you do, the pump is working. If you don't hear it, the pump is bad or the wiring to the pump is not working. Check the relay.
Usually, on a four cylinder with multi-port injection, injectors 1 and 3 fire simultaneously, and then injectors 2 and 4 will fire at same time (because their ground wires are spliced together before entering the computer. When the computer internally grounds the wire, the injectors will pulse). Are you certain that all four are pulsing at same time? If so, that may be the Mazda way. But I think you are right to believe it is a fuel problem. Test the pump as stated above, key on (not start) and listen for pump to turn on.
Good luck.
