Heating & Cooling Logo
Kingsley Bowder Posted on Mar 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can any body tell me where i can buy a new curcuit board for a Hitachi aircon RAC-35YHA1, after going through this site it may be the prob with it, it seems to come on and the just goes on to a low fan speed and the compressor won't run, there was quite a few ants on the main pcb on the outside unit...
John
Level 3:
  • Master 794 Answers
  • Posted on Mar 08, 2014
 John
Master
Level 3:
Answers
794
Questions
Helped
290905
Points
3169
You can purchase the board at any HVACR wholesale-distributor supplier / warehouse that deals in and with Hitachi products.
[Heating Ventilation Air-Conditioner Refrigeration]
Check the yellow pages of your phone book or call a local heating and cooling company and ask them what supply house they get their equipment from; perhaps they'll help. Some, if not most supply houses deal with licensed tradesmen only; for liability purposes and to protect the tradesman's business ($$$).
Try Grainger, Tower Equipment, Bell & Simmons, Torrco, B. Lipnick Supply Company, Johnstone Supply, Allied Supply Company, Ace Supply Company, Lewin Plimpton & Hill Supply. I hope my suggestion work out for you- best wishes.
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 17, 2008
SOURCE: intertherm outside unit - s3ba-036k - does not run
Measure the voltage across the line. The outside unit normally runs on 220 Volts. Measuring each side of the line to ground will give 110 Volts. If your outside disconnect is of a fused type one fuse could be blown. If a fuse is blown on one side of the line you will read zero volts differential across the line.
Check the type of fuse used in the disconnect. Make sure the proper size time delay fuse is installed on both sides of the line at the disconnect.
Anonymous
  • 10 Answers
  • Posted on May 31, 2009
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Anonymous
  • 4 Answers
  • Posted on Jun 18, 2009
SOURCE: Blowing hot air, compressor not kicking on, just fan ? ?
are you speaking of the outside fan or inside? compressor should be a little warm but not boiling hot. the unit could be low on freon. if low it will run a while but the compressor will overheat and shut off leaving the fan running by itself ouside. if nothing outside is running check power. if you have power check the contacted outside to make sure it's pulled in. contacters are bad about going out on goodman untis. Also ants can get under contacts.
Anonymous
  • 534 Answers
  • Posted on Aug 04, 2009
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
Dane-1
Dane Berg
  • 3 Answers
  • Posted on Feb 08, 2011
SOURCE: c6 error code on LG art cool
Condenser fan windings are rooted. No capacitor due to multi speed. Replace condenser fan motor they just clip on pcb.
Hitachi 60 60ux588
Its main power regulator board has damaged. It will be best repalce this as card basis. Actually replacing it is a semi-skilled work. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
1helpful
1helpful
2answers
My hitachi plasma tv model P50S601 only flashes a picture for a second before going black. Once it goes black, the blue power button flashes and can't be turn off by the remote or by manually pressing it...
These tv's are know for this. I have a topic about it telling you how to test and repair these at http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
p50s601 and p50h401 are basicly the same tv but the p50h401 doesn't have the swival base.
these sets are known for two caps to go bad in the power supply and then most likely it fried out one or both of the driver boards. the driver boards can be repaired. a company that repairs them is listed in the topic. or you can buy new driver boards.
2answers
After a few weeks of buying my tv hitachi 42" lcd l42x02pxw istarted to have problems wih it. i use the remote to turn it on and off. the green light turns on however theres no picture. the tv screen is a...
If u buy this new,u got a lemon,This prob.is a
burn in use equipment,shouldn't cause this prob.for at lest 2 years.This is a comon prob. with a video Wharping heat exspand and contrast circuit board.
Curcuit Board Damaged - Akai PT5499HD
go to the following link they will most likely have a new replacement board for your akai, and if not they remanufacture boards as well. Leave them a email by clicking on the contact button. http://servicemanuals.vstore.ca/
FRONT CURCUIT BOARD HAS BLOWN.
Try emw electronics web site. Never let me down yet..
1helpful
Power won't stay on MdL 46EX3B/4K
check the curcuit board where the power supply is sometimes these sets get so hot the solder melts causing short curcuits,be very carefull as tvs can hold high voltage for many years and should be discharged first,there may be signs or arcing near power supply hope this helps...
Manual Start - Hitachi Iota
just buy a multi-purpose remote control and set in the users code lo...like that even don't have original remote control your aircon still can use until your are ready to buy a new one lo...
Top Hitachi Heating & Cooling Experts
jws1013
john h
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
