Nintendo Wii Console Logo
A
Anonymous Posted on Feb 21, 2014
Wii won't recognize remotes - Nintendo Wii Console
none
Level 2:
Sergeant:
  • Expert 137 Answers
  • Posted on Mar 01, 2015
none
Expert
Level 2:
Sergeant:
Answers
137
Questions
0
Helped
28265
Points
543
You need to pair new remotes before you can use them. There are two buttons you need to push. One is under the battery cover of the Wii remote. The other is under a small over on the front of the Wii (where SD cards are inserted). Press the button on the remote and then the button on the Wii. The lights on the remote should flash for a bit and then stay on.
My wii remote won t work
i have netflex and my remote stopping working i changed batteries but cant find the arrow it isn't showing up at all. WHY?
tip
2nd wii remote will not connect
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
tip
try this!
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
      Try these steps!
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC" Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • 0helpful
    My wii starts up fine..but once were at the main screen it won't allow u to select any of the channels not even if a games in it...u can glide the remote over the channels and it recognizes them, but...
    hi there, it happened the same to me, i only changed the batteries and blew into the button to take away any possible dust in it, because the a button might has stopped working, did you try with a different remote?
    3helpful
    Wii will start up and run fine but the wii will not reconise any contol. I had sensor bar tested and it is fine. It hasto be in the cosol itself right?
    No the sensor bar just recognizes the position of the remote. If it doesn't recognize the remote at all, it may need to be resynced. Turn on the Wii and the remote. Take the battery cover off the remote. There is a small red button. Now open the small trap door on the front of the Wii. Another small red button. press the red button on the remote first. The blue LEDs on the front will flash. Now press the red button on the console. If the LEDs on the remote stop blinking that means it paired up. Will have to do this for all remotes.
    Please Rate!
    5helpful
    2answers
    Unable to setup second hand control , now doesn't recognize either
    Hold the Wii Remote with the button side down. Without using much force, firmly tap the button side of the remote against the palm of your other hand a few times. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard. Check for proper response. If the problem is not solved, please follow the rest of the instructions on this page. For all Wii Remote issues: If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info). Make sure you are using fresh batteries in the Wii Remote. The Wii Remote Controller should be used between 3 to 10 feet from the TV. Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote. Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves. Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
    Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common: Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, Try these steps! Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes: With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture). When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4). This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    1helpful
    My Guitar Hero 5 Guitar will not work and is not recognized by my wii
    if your guitar is not recognized mabe its the control open the cover at the left of were to put the wii disc and open the cover of the wii remote in the batterie cap and press sinc in the wii remotes dont leave it pushed for more than 10 seconds then try it
    2answers
    Actions are reversed
    Wii Remote Troubleshooting red_circle_arrow.gif Important Safety Information for Playing Wii red_circle_arrow.gif Wii Remote Wrist Strap Replacement Information Quick tip: Cursor (hand) or character movement not responding properly?
    If you are experiencing problems with a new Wii Remote, or are having difficulty with a Wii Remote that was previously working properly, please carefully read and follow the instructions on this page. First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
    • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
    • Make sure you are using fresh batteries in the Wii Remote.
    • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
    • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
    • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
    • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
    Still having problems? If the basic guidelines above did not solve your problem, the more specific information below may help.
        Try these steps!
        3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
      Tilt Problems
      1. Check the motion sensor functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
      2. Try placing the Wii Remote in a neutral position by resting it on a flat surface during game play. If the character or cursor still tilts on its own, there is a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
      ^ Back to Top
    1helpful
    Lego games on Wii won't recognize remote
    Make sure that you press the + button on the second remote to join in.
    2helpful
    Wii remote keeps beeping and not working
    try this! I found it on Nintendo.com under support:
      Try these steps!
  • Not finding what you are looking for?
    Top Nintendo Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Aron
    Sean Wright
    Sean Wright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
