SOURCE: Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
SOURCE: the macerator wont stop
sounds like youve got a "leaky" wc cistern which means your bowl will fill intermittently and then operate the macerator in the same manner. call a plumber.
SOURCE: My sanibest system is not working properly. When I
you need to unblock the system... it is too full and need to be empty.
SOURCE: How can I adjust the water level inside my Saniflo
you cant it is set by the bends in side the bowl all toilets are this way it is a trap design that keeps fumes from septic from comming in
SOURCE: Sanipro continuously runs,however, not pumping
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
