Computers & Internet Logo
r
robert4490796 Posted on Jan 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor changed from 32 bit to 16 bit
Monitor was 32 bit now 16 bit
Stan Skaggs
Level 2:
Novelist:
  • Expert 242 Answers
  • Posted on Jan 30, 2014
Stan Skaggs
Expert
Level 2:
Novelist:
Answers
242
Questions
Helped
100142
Points
454
Go into video mode screen and check on your video driver for the video card.
3 Related Answers
Anonymous
  • 14 Answers
  • Posted on Jan 04, 2008
SOURCE: having problem with syncmaster793df
check the refresh rate, and other related adjustments
Anonymous
  • 19 Answers
  • Posted on Jan 16, 2008
SOURCE: i have lines over my monitor
Dear Mihajlo,
Your problem isnot monitor but VGA adapter, you have to install different(adequate) driver or if it isnot useful to change VGA card. Check for new driver at the VGA card manufacturer site.
Best regards.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: Monitor Help
I had the same pink problem. In my case when I reconnected the monitor cable to the moinitor,I accedently bent a little wire in the connector. I straightened it out, reconnected it and it was able to mate with it's female counterpart and the pink went away. Hope this might help someone.
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
Pixels only goes to 640X480
When you cannot increase the screen resolution nor a higher color bit, this usually means the video driver has defaulted to standard VGA driver and 8 or 16 bit color.
Install or re-install the latest video driver for your model video card.
When the correct video driver is installed you will be able to change the screen resolution and 32 color bit.
My color monitor (hp pavilion mx70) is having graphics problems
Need to download correct graphics drivers and then you will be able to change the options. If you already have up to date drivers then you need to Right Click on desktop and select properties and then click on the Settings Tab and change it from 16 color to Highest (32 bit). Oh, go to manufacturers web site to download drivers.
How to change monitor resolution?
Probably there are another available solutions but I think you should respect the monitor native maximun recomended resolution taking into consideration to change (if it is posible) between 16 or 32 bit of deep.
I have the same monitor as you have.
Hope, temporaly it help.
3helpful
Monitor Help
Flicker and Noice
1.try to change a screen resolution on your monitor. if did not solve your problem
2.change the colour quality either 32 bit or 16 bit
try your best.
please rate this solution whenever.
1helpful
3answers
6 mo old amw monitor A913B 19
Same Monitor, same problem. Solution: I changed the colors setting to 16 bit from 32 bit, and that cleared the problem. I then changed back to 32 bit and it still worked. How long, not known yet. So , go to display settings, find COLORS: and then change to 16 bit.
I have lines over my monitor
Dear Mihajlo,
Best regards.
Having problem with syncmaster793df
Grand Canyon Tech
Grand Canyon Tech
