Heating & Cooling Logo
Posted on Jun 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What gas is used in fiat ducato 2.8jtd
Air conditioning unit will not cool down enough
Anonymous
Level 2:
  • Expert 142 Answers
  • Posted on Jun 05, 2009
Anonymous
Expert
Level 2:
Answers
142
Questions
0
Helped
61053
Points
418
Under the hood there should be a label with the type refrigerant used as well as how many pounds of refrigerant are used. Typically this is located near the front radiator support.
1helpful
I have a fiat ducato 1988 that when i put in gear it does not drive ,i can put in gear without pressing the clutch down any ideas
Could be anything from a broken clutch to a broken drive shaft. I once had a customer with that trouble and the outer cv joint and drive shaft had lost all it's splines.
Another customer had an engine mounting break allowing the power unit to drop far enough to disengage a drive shaft from the transmission..
Only checking will reveal the problem...
Manual on Fiat Ducato 2.8 diesel 1999
See if this helps. Third selection down is downloadable Fiat Ducato Training manual. Enjoy
Ducato
Fiat Ducato 2.8 turbo diesel manual
See if this helps. Third selection down is downloadable Fiat Ducato Training manual. Enjoy Ducato
2answers
How do I bleed the cooling system on a fiat ducato 2.8 disel
on any car with bleeders as they will look like brake bleeders on but located in the cooling system,with motor off crack them open one at a time ,this is best to do when motor is hot be careful as notto burn your self and has pressure in system ,once you open one watch for air to come out once you have a steady stream of coolant coming out close,then do other bleeders,next to do it when motor is running and bleed them ,that should do it.
hope this helped.
Woody
Show me the fuse box schematic 2010 fiat ducato
On this website (link below) you finde fuse box diagram, description and loaction for Fiat Ducato mk3 (2006 - 2014)
Fiat Ducato mk3 2006 2014 fuse box diagram Auto Genius
Fuse box location fiat ducato 2009
On this website (link below) you finde fuse box diagram , description and location for Fiat Ducato mk3 (2006 - 2014)
Where are the fuse boxes on a fiat ducato 2008 model
On this website (ink below) you find fuse box diagram, description and location for Fiat Ducato mk3 (2006 - 2014)
FIAT DUCATO 2005 WHERE IS THE FLASHER RELAY UNIT INDICATOR ON LEFT SIDE DON'T WORK, HAZZARDS ON LEFT SIDE DON'T WORK, ITS NOT THE BULBS AS ALARM FLASHES ALL 4 INDICATORS.
2006 fiat ducato left indicator only flashes a couple of times then stops also the hazard lamps only work on right side
Top Heating & Cooling Experts
Paul Carew
john h
