The flat's fuse blows everytime I put on the Zaffiro. I have pulled off everything i my flat when I'm trying to put it on. I have looked over every cable inside without sign that anything is wrong. If it depends of the heater fuse I think the machine should start and goes off after a while when its to hot?
There is no reason why any coffee maker by itself draws so much current that it causes a main fuse or breaker to open. If you are shutting down all electrical use such as other appliances and lights and the fuse is still blowing, you need to have an electrician analyze the flat wiring and the over current protection devices (fuses, breakers) for malfunctioning or perhaps inadequate capacity.
