From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears.
One of the most widely used grain mills is the country living grain mill, it is known for its stable build and lifetime warranty. Every so often when you use your grain mill frequently you will need to clean it out to keep it functioning as properly as possible. Luckily cleaning the Country living grain mills are very easy to clean.
First you want to disassemble the grinder, by removing the adjusting knob off of the front of the unit. Make sure that you don't lose the small square piece that keeps the front plate form spinning with the shaft. Behind the knob you will find some washers and the burr. You can take out the burr and use a small brush to clean out any flour than may have gotten caught inside.
Some times you will need to clean the grinding plates this can be done by using the wrench that came with the mill to remove the screws that hold the stationary plate in place. When the plates have been disconnected they can be taken out of the unit for a more thorough cleaning. If you wash them in water make sure that you dry them well immediately to prevent them from rusting. These grinding mills were not made to be washed in water, therefore just using a damp cloth should be thorough enough to clean the whole unit.
When you have finished washing and drying the pieces its time to assemble your mill. Before you put the plate back inside make sure that there is nothing inside the unit because the plate will not reattach if anything is in the way, all the mounting hole have to align before you move on to the next part of the mill. Then follow the disable instruction the reverse order, replace the burr, washers and knob. Wallah! you now have a clean grain mill ready for use.
Most of the mills that you will see on sites like amazon are hand mills but I found the Nutrimill to be a really amazing machine mill, its quiet and quick and has many different settings. EQUIP Nutrimill Grain Mill Amazon com Kitchen Dining
There are two stones that are both circular. One stone turns and the other doesn't move. The turning stone will have grooves from the stone's centre to the ends, with the grooves getting more shallow as they reach the edge. the grain falls through an opening between the stones and then the grain is ground and the flour falls to the outside.
Will it grind any wheat? I had a similar problem with the wheat overwelming the drive system and had to use smaller amounts of wheat to keep the system grinding. Do you have the feeder attached? I couldn't just load it up but had to feed a little at a time. Hope it helps. Favorable comments are apprieciated.
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
