Gear Head Wireless Optical Tilt Wheel Mouse  Logo
Posted on May 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The mouse do not work after I restart my computer
After I restart my computer the mouse dont work, I have to unplug and plug the USB cable to fix the problem. the mouse it's a wireless gear head
Anonymous
Level 3:
  • Master 822 Answers
  • Posted on May 31, 2009
Anonymous
Master
Level 3:
Answers
822
Questions
Helped
240430
Points
2570
Check battery. press reset button both usb and mouse.
How do I use mouse instead of touchscreen on Samsung laptop
Do you have a mouse connected by cable or a USB dongle? If so, then your computer's Plug and Plug (PnP) capability to detect, install and activate peripheral device drivers will have recognize the mouse and made it accessible to you. If the mouse in not usable, look in Start, Computer, System Properties, Device Manager, Mice (etc.). If you have a Yellow Triangle, click on the mouse then the Driver Tab to Update the driver. This should solve you problem. You may have to Restart to gain access. If that doesn't work. Unplug the mouse connection, Restart the computer, then plug the mouse connection in again. Watch to see if PnP detects the connection and installs it.
2answers
SAMSUNG YP-T10J
First disconnect PC from power cable for 10 minutes (unplug).Disconnect player from USB. reinstall player software. Then connect back player, it should work.
tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
Mouse not working
Mouse is a short life device. If your used it more then replace a new mouse. Because if your repair it cannot succeed. And cost a double charge .. So Purchase a new mouse..
May its cable cannot connected well to computer...
If You have usb mouse change the usb port and place on other usb port... If this not works remove mouse..
If you use ps2 mouse this type of mouse dont detect if your connect on pc on mode.. So restart your computer to find your mouse...
Hope this will help you...
Aspire AsT160-Ua352H, Acer, desktop............Problem is when turn computer on, I can see the desktop page but the mouse is frozen, will not move, but the mouse is working on another computer. The...
With the computer running, unplug the power cord from the computer. Make sure the mouse is plugged in before you plug power back in. During restart after the forced crash the system will re inventory the hardware. If it is a PS2 mouse, and crashing did not fix it, the quickest fix is to retire the mouse and buy a USB or wireless (also USB). The USB mouse seems quicker than the PS2 and they are cheap. Plug in the new mouse, turn on the computer. Plug and Pray.
1helpful
My wired usb Gear Head mouse stops working after a few minutes. I can unplug, then plug back in and it work fine for a few minutes, repeat...what's wrong?
the connection of your usb mouse maybe unplug unaware due to motion of your arm...
some operating system will not work until you safely remove and plug it in...
computers component/plug-ins are sensitive...when they're disconnected while in operation it may cause malfunctionality until you restart your computer....
2answers
Mouse frozen which keys to use instead my lap top works how I am able to write now. My Desk top computer mouse is frozen?
If you were using a physical mouse (instead of a track pad), then try a different mouse.If you were using the track pad, get a USB mouse and plug it in. If it works, then continue to use the USB mouse. If no type of mouse will work at all, it is a software issue. If rebooting doesn't fix the issue, you may have to reinstall windows. If you are using a mouse with a driver that was installed using a disk, try uninstalling that driver from the add/remove programs window (programs and features wind on vista and later).
Ok. hello. my name is James. i am a student in high-school. and I'm having problems with my computer. Since i got my computer everything has been working great and i haven't had any problems, however, for...
Try this fix, turn off your computer properly then unplug the computer from the wall socket, then press the power button and hold for about 3-5 seconds. Then plug your computer back in, restart the computer then wait for the boot to settle into Windows.
After doing those things plug in a USB device into the same port as you have been doing. It should work now, if it does not plug it into another port if it does not go to all of the ports and try them all if none of them work then you cable may have come loose on your board or it is a bad USB HUB on your computer it is obvious it is not the unit if it worked on another computer.
You will have to replace it or if it works on one of them then change out the bad one. Replace it! Or go and get a 4 port USB extension using just one of the USB ports. So that you will have more ports without the fix. Replace any worn parts or devices that do not work anymore. John
Keyboard and Mouse don't work anymore
Hi, Sorry you are having problems,
Well Marcelo, the first thing to do in a situation like this is to restart your Mac or even better, shut down and restart. So, if you have done this, and still the keyboard and mouse don't respond, and, as you have mentioned, you have tried the other USB ports on the back of the Mac, it sounds like somehow, unexpectedly, your iMac motherboard got a shock of some kind and it killed the USB controller....
Last thing to try is to unplug the iMac completely of everything and let it sit for 10 minutes and then plug just the keyboard and mouse back in and try to see if that does the trick..
Otherwise, Apple will cover this if it is still under warranty.
Good Luck.
I was playing my computer game last night when my wireless mouse suddenly stopped working, I placed new batteries in as this is the usual solution but it does not seemed to have worked. I know its not the...
First turn off your computer let it rest for about 5 minutes. Then restart it again. Usually this is all what systems need. Next try checking the usb attached to the computer before turning it on again. Plug and unplug it. If there is no major problem on your mouse. This should do the trick. Please dont forget to rate me. Thanks!!!
Top Gear Head Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
