1990 Mitsubishi Eclipse Logo
Maryann Catanzaro Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car wont start but the alarm goes on and it never used too
Car was starting fine . washed and waxed it then. never used the alarm didn't think it worked. now the car wont start and alarm goes on
Jun Magno
Level 2:
Sergeant:
Habit-Forming:
  • Expert 175 Answers
  • Posted on May 30, 2009
 Jun Magno
Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
175
Questions
0
Helped
97399
Points
522
Try removing the battery + for at least 2 minutes. it should reset the alarm system. if it doesnt work you need to make your remote work try replacing the batteries and try it
Trailblazer won't start
Open the door,when alarm goes off insert key into ignition and alarm should go off and it should start,try that.
1995 vw golf wont start after changing battery.
Here is a useful link. Go to it, and look for the text, "Disconnect the battery" ... Read the steps to solve your problem!
www.justanswer.com/vw-volkswagon/1y9u8-reset-anti-theft-alarm-system-1995-vw-golf.html
How can I disarm the Alarm. I bought my 97 Cabrio used (it didn't come with the remote) The Door locks also don't work. I can't drive it because when I turn the key the alarm goes off and it...
If you don't have the remote then its pretty much useless. I have seen at Pep Boys where they sell replacements for the factory/dealer installed alarms. Or just remove the alarm completely and reconnect everything the way it was.
Without knowing what brand alarm it is a person cannot honestly answer how to disarm it as they all work differently.
If you know a brand and model you may be able to find downloadable instruction on the manufactures web site.
My acura 3.5 RL 99 will not start properly. I even change the gaz pump. After starting, it dies after 2 seconds. No gas goes through I noticed before some problem with the alarm system. When the alarm...
there are many things that can cause stalling a dirty iac (idle air controller) is just 1 of them, clogged fuel filter is another, water in the fuel, clogged air filter, and don't even get me started on alarm systems, especially after market alarms can all cause issues, it could also be a bad mass air flow sensor.i would go least expensive to most expensive, start with cleaning things before replacing them
2006 cts, several times now after washing vehicle the car stalls out, idles ruff then stalls upon starting. then car wont start at all and when trying to start car the electronic ignition keeps rolling...
water is getting into the harness connections for the ECM
use water displacer ( wd-40 or the like ) after a wash or find where the water is affecting and use a spray wax to cover all of the electrical connections
4helpful
Was washing and waxing 1997 volkswagen cabrio with radio on, ignition switch turned to on. Opened Driver side door, depressed clutch and brake, as usual, turned key off and then back to on position to...
put key in door lock,unlock/hold key over windows will go down....then lock/hold key over,windows will go up,press and hold unlock button on remote for 30 secs,you have just reset the alarm/immobiliser.
2helpful
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
My Car wont let me start it
Well, my mom found a little button underneath the dash board on the drivers side. And I guess its kind of like the reset button. So she pushed it and started the car and it was fine!
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
