2002 GMC Envoy XL Logo
Posted on May 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AC blows hot air
I disconnected battery on 2002 envoy to reset ''service engine soon'' light - now ac blows hot air and idle is very rough - sometimes dies at idle
Anonymous
Level 3:
Brigadier General:
  • Master 3,533 Answers
  • Posted on May 25, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
3533
Questions
Helped
1421205
Points
10516
Try this website fix & troubleshoot heating & A/C www.automedia.com and another car A/C repair www.directgardening.com
2answers
My 2004 Envoy XUV 6 cylinder is misfiring with a flashing Service engine soon light immediately after the AC Compressor was replaced
Rob, when the battery is disconnected for any reason a couple of things happen, and frankly it's a design error on the GMT360 platform (Envoy/Trailblazer). Your mechanic did not make an error here. Issue #2, your vent actuators blew out when the battery was re-connected back up, it happens, it's common. Issue # 1 is a little more complicated. The flashing light means misfire, is a seperate issue and a coincidence. Pull the codes out with a scanner and report back, may be bad coil pack, happens and is common. Idle problem and starting to die is an easy fix, betting it only happens when the AC or defrost is on. Disconnect fuse #10 and #28 under the hood. Remove the throttle body and clean it with a sensor safe spray like Seafoam. Drive it around for the computer to relearn the newly cleaned throttle body. Idle problem will be fixed.
1helpful
Engine idol rough sometimes stalls when air conditioner is on but ac does fine at high speeds
Throttle body needs to be cleaned, make sure both front side and rear side are cleaned thoroughly. Also, disconnect battery while performing cleaning, this will reset computer and allow it to relearn to the newly cleaned throttle body.
4helpful
2002 GMC envoy slt 4.2 v6 My question is.. I recently changed the water pump on my wife's envoy. After replacing it the car idles low and high, low and high constantly. No normal idle like before. I...
Sounds like you may have disconnected the battery. Does the rough idle only happen when the defroster or A/C is on? If so clean your throttle body with throttle body cleaner with the battery disconnected. When finished, drive it for 5 or so miles with the defroster / AC off to let the computer relearn the settings. This will solve your problem.
2helpful
Engine bogs down when ac kicks on
Check the Idle Air Control Valve. Any Service Engine Soon lights coming on?
4helpful
2answers
Replaced coolant sensor on my 2004 GMC Envoy XL 6 cylinder. I had to disconnect the battery and alternator. All was reinstalled,truck runs fine but when I turn on the a/c the truck turns off and idles...
Sounds like ac compressor is dragging.It might be that rpm is to low also.Step on the accelarator and if you have a tach bring rpm up to 700 to 800 in drive which is were it should run with ac on. With ac off rpm should read around 600 in drive.
10helpful
2answers
AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
1helpful
2answers
Rough idle
sound slike you may have unplugged or disconnected somethine else or the spark plug you put in is bad or inpropper gap
Blows hot and cold-restart and problem disappears for a while
you need a servicing of the ac condensor, also check that the blower is working or not. your problem will be solved by servicing the condensor.
2helpful
2answers
AC blowing Hot air after battery was disconnected
TRY DISCONNECTING THE BATTERY FOR 5 MINUTES AND SEE IF IT COOLS AGAIN, SOUNDS LIKE A TEMP CONTROL BLEND DOOR PROBLEM. DISCONNECT THE NEG CABLE OF THE BATTERY.
1999 540i AC problem
tom disconnect the battery for 5 minute hook it up and try it if ac work sometime computer shot out you disconnect and it reset the computer it hapen to me on my 98 540 good luck pierre
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
