How to remove Bose audio fuse located under the hood near the battery. I removed the plastic cover that sat over 4 fuses, the one at the end is the audio fuse 15amp, 12v
Question edited for clarity. Your vehicle is not an 'infinite. it is an 'Infiniti, and it is an 'FX35', not and 'FX3', plus it is 'YouTube', not Tube'. If you can spell it you can find it :>D
YouTube is for videos, not for finding fuse box data. The Radio is listed as 'Audio' and has 2 fuses. BUT, did you disconnect the battery recently? It the 'radio' asking for the code?
Raise the hood of your car and look near the battery for a black, plastic box. Unsnap the lid and raise the cover. On the inside of the lid there should be a schematic of the fuse orientation, and inside this box there should be an array of circuit breakers, fuses and relays arranged according to the schematic. One of the small, black relays is likely to control the fuel pump. Near the relay there is also typically a red, 10-amp fuse labeled "FUEL," "F/P" or "FUEL PUMP." If not, check under the dashboard.
If its under the Dashboard
Use a flashlight to look under the dashboard. In most cases, there should be a lower cover to access the fuse panel. Remove the cover with a small screwdriver and pull the lid off of the fuse panel. On the inside of the lid there should be a label that identifies the fuse arrangement, similar to the label on the power center under the hood. Look for the same lettering that designates the fuel pump fuse. If the fuse is not there, look in the specialty fuse panels.
somtime the fuse panel is on the driver side kick board under the dash. There is also a fuse box under the hood usually covered with a plastic cover. easily removed
Probably under the hood. Look for a plastic cover under the hood near the front of the engine compartment. Remove the top, and you should find your fuse box.
There is an ipd/m fuse box behind the battery of my 2004 infiniti g35 sedan. I blew a fuse and couldn't find it. So remove the plastic panel that is right next to the windshield washers when the hood is open. You'll see an entirely new fuse box. So all in all, there are three fuse boxes... one by your feet on the driver's side, one in front of the battery, and one behind the battery. hope it helps TF
(1) possible blown fuse. Note that fuses blow for a reason - seek out the reason, or it will blow its new fuse too.
The main fuse block is located inside the left side of the
engine compartment near the battery. There is also an interior fuse
panel located just above the left side kick panel.
Interior Fuse Panel The interior fuses simply unplug
from the fuse panel. Use the fuse puller tool provided with your car to
remove fuses from the panel. The tool is located on the back of the
interior fuse panel cover.
(2) possible blower motor dead. See maintenance manual excerpt below.
(3) possible blower motor relay faulty. Location of Blower relay: Under hood, drivers side, front engine area,rear of headlight housing; relay mounted on drivers side of radiator shroud.
1990-92 Mazda 626 and MX-6 See Figure below
Disconnect the negative battery cable.
Remove the glove box and the underdash cover.
Detach the electrical connectors from the blower unit.
Remove the blower unit-to-fire wall attaching bolts and remove the blower unit assembly.
Remove the blower motor fan-to-motor fastener.
Remove the blower motor-to-unit attaching bolts, then remove the motor.
Installation is the reverse of the removal procedure.
Hello: Instrument panel fuse block- located on the instrument panel (passenger side consel) near the
floor. Remove the panel then the fuse block cover. Engine compartment fuse block: Under the hood on driver side near the battery. You may have to remover cover to access the fuse block. Rear compartment fuse block Located in the trunk. Access the fuse through the trunk panel on the driver side. The inside of the fuse block covers give you the location, size of fuse and purpose. Hope this helps.
Look under dash on drivers side, for a black removable plastic panel, that covers the fuse panel. Also, depending on what fuse your looking for, there should be a fuse/relay box under hood on drivers side near strut tower. The map for the one under the hood, is usually on underside of cover.
in the engine compartment near the battery you should see a flat plastic cover with tabs on each end... remove that and there are fuses and relays under it. the fuel relay should be there.
