SOURCE: tryng to drop gear box off 6hp johnson how to?
If you are talkinh about unhooking the shifting rod from the lower unit, it might be behind a small plat held on with 2 screws on the side of the motor towards the bottom (casing that the lower unit dropped out of) or look uo in the housing , you should see how it is connected, usually a small bolt
SOURCE: 140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
SOURCE: 2 or 4 stroke engine
2 stroke.Fuel/oil ratio is 50/ 1.50 parts fuel,1 part oil.They are a very good reliable motor.Hope this helps
SOURCE: how to adjust timing on johnson 6hp outboard motor
look at a manuel i think it is automatic in the switch no manuei adjustment get it timming through the cd like some of the mercks
