You need to clean the fan blades to stop it. Due to blades getting covered by dirt your fan cannot throw out the heat. thus it runs more fast and makes noise. also the heat sink gets covered by dirt unable to radiate heat . thus your laptop gets heated fast. clean those dirt and the problem will be solved. thanks.
If this is like most Notebooks and Laptops, there is a switch to turn the WiFi off and on. This switch will either be a physical switch on the outside edge of the computer, or a soft key switch on the keyboard. for a softkey, look on the keyboard for a light gray are blue symbol that looks like an antena with lines coming out of it. Hold down the Fn key while depressing this key. This should turn the WiFi back on. If its a physical switch, try a different position on the switch and see if that kicks it back on.
I had the same exact issue. I could see the wifi signal and could input the password to get into the network but it would not connect. I did what the following website suggested and it fixed the problem!!! http://baudizm.blogsome.com/2008/09/25/making-wifi-work-on-msi-wind-umpc/
You need to update the driver for wifi adapter. The driver for the wifi connection you are using in linux is compatible to it but this driver can not get support to your xp sp3 to get compatible.
If there's a local WiFi connection, it happens automatically. If you don't have local WiFi and a login and password, then you can't connect to the internet.
