Computers & Internet Logo
f
frankie kim Posted on Jan 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Font sizes are too big and poor clarity of video
GetVladimir.com
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 92 Answers
  • Posted on Jan 04, 2014
GetVladimir.com
Expert
Level 2:
Filmmaker:
Answers
92
Questions
0
Helped
13219
Points
205
If this hapens in your Internet browser (Google Chrome), hold CTRL and press - on your keyboard to get the size back to normal.
Font size on email is too big, how to get it smaller
If you mean that when you write emails the font size is too big, you need to do the following in your email programme (I'm quoting Outlook):
Go to Tools, Options, Mail Format This will open a multi choice window.
Click on Fonts (under Mail Format)
This gives you the opportunity to change the font, the size etc.
Under 'When composing a new message' click on Choose Font. Change the size to something smaller 10 or 12pt are best.
Don't forget to click on OK at the bottom of the window.
Hope this helps.
tip
Common Projection TV Problems and Fixes
In this article we will will outline some of the most common projection TV problems, fixes, pros and cons, and average lifespan.
Average Lifespan: 7-20 YearsPros: Large screen size and excellent picture quality. Some model support HD. Very reliable when they are cared for.
Cons: Heavier and bulkier than the newer plasma or LCD sets so if you live in a cardboard box it may take up a bit more room.
Common Problems/Fixes
Common Problem #1 - Convergence: One the most common problems that you will run into eventually is a convergence failure. This is when the TV colors do not align anymore and the TV will look 3D, warped or distorted. This is a very common problem and a fairly simple DIY fix. Parts to repair this can be found over the internet from sites such as www.TvRepairKits.com . Below are a few photos of a typical convergence problem and a link to a video on YouTube with more details.
utube.png You-Tube video "9oI1Nzq7CR8" placeholder (do not delete) utube.png
Notice how the image looks 3D...this is a classic example of a convergence failure...it may also look warped or have a wave look. But the wave will not fluctuate.
Common Problem #2 - Dull or Dark Video
The second most common problem we see on projection TV sets is whats known as the dull video issue. This is commonly caused by discolored cooling fluid in the lenses. Over many years - usually around 5-7 years - the fluid will discolor and cause the video to wash out or look dull. Changing the CRT fluid out every 7-10 years will restore the image clarity back to factory new conditions. You will actually be amazed at how sharp and clear the video looks once a fluid repair has been done.
Here is a before and after photo notice how it looks washed out. In some cases the images will look like they have halos around them or the screen will have a reddish tint. Bottom line - if your projection TV has never had the lens fluid replaced the video is not as sharp as it can be. You can get fluid kits from the same sites mentioned above. Doing this repair yourself or through a shop will make the video look amazing.
After a fluid replacement
Common Problem #3 - Dead set with no videoIn these cases there can be more than one common issue depending on the TV brand and model. But to make things simple if the TV has no audio or video and its making a constant chirping sound the issue is caused by a short in the convergence. The fix is to do a convergence repair. If however its not chirping constantly it can be one of many issue from failed capacitors, diodes, flybacks, etc.
on Apr 25, 2012 • Televison & Video
2helpful
2answers
The font size of my messages has gone very small
1- Go to messages
2- Select message settings
3- Select font size option
4- Set the font size mentioned in the list for your need.
1helpful
Hi,how can i change font ( big size )in Nokia N900
hello,please kindly move under your settings,you will then see display settings and click on font,there you can change it to whatever font you desire.
please kindly rate the solution if it's helpful,
take care.
Need to increase font size without effecting pixel clarity
The first step for optimal readability is to set your PC's graphic output to the native resolution of your monitor.
The Samsung 2033SW is a little unusual in this regard since it provides a matrix of 1600 x 900 pixels, which is not very common.
If your graphics board has DVI output, I'd also make sure to use a DVI cable to connect to the monitor instead of VGA.
Windows XP and above support a font rasterization technology called "ClearType", see http://en.wikipedia.org/wiki/ClearType. This page also provides references to the ClearType tuner PowerToy for XP, which is available to Windows users at no extra charge. Windows 7 has a control panel for ClearType out-of-the-box.
If you still need to increase font size, you can increase it from the Display Control Panel, too, "Medium" font size scales to 125'%, "Large" fonts to 150% the normal size.. Changing the DPI (dots per inch) setting in the monitor control panel cannot be recommended since some software cannot cope with alterations here (dialog boxes or user interfaces with text in wrong places or sticking out of the window... yeeks.)
4helpful
HOW TO MAKE BIG FONTS OR BIG NUMBERS IN N72?
To make the letters and numbers big fonts, go to menu>message>message settings>font size and choose the font size you want.
Grand Canyon Tech
Grand Canyon Tech
