Toys Logo
A
Anonymous Posted on Jan 02, 2014
Hak 301 with no on and off switch - xheli Toys
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Nokia 301 restricted on meteor
Hello. Do you want to unlock your Ireland Meteor network restricted Nokia 301? If so, you can visit ClassicUnlocking.com and get the unique unlock code at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia 301 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 301.
3 - Compose #pw+CODE+1#.
4 - The Nokia 301 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 301 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 301
Nov 18, 2014 • Cell Phones
Garmin foretrex 301 will not power up
Replace it. I think the battery is dead and unless you are up for cracking open the case it is done done for... You can always try a mast rest first though... Just google that one.
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
2002 Lincoln LS. Now im getting PO301, PO316, P1000, P1565.
Code 301 is a miss on cylinder one.
Code 316 is for a miss on startup which would be connected to code 301.
Code 1000 means the computer self-test did not finish.
Code 1565 is specific to Ford products and means the cruise control system failed to engage - command switch is out of range.
Someone will need to check cylinder one to find the main problem. Code 301 means the cylinder is not producing power but not why. It could be ignition, fuel, or mechanical.
2helpful
Operating manual 3018ar
There is a 301 digital timer:
http://waterheatertimer.org/pdf/301-0005-Digital-Time-Switch.pdf
Copy following links to help identify your timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Card locked
Most SD Memory cards have a little switch on the side to lock them, try switching that to the other position.
Top xheli Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a xheli Toy Expert? Answer questions, earn points and help others
