Cars & Trucks Logo
C
Cathy Etzinger Posted on Jan 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hyundai H100 2010 cam belt timing marks
Need a diagram for the cam belt timing marks also the torque setting sequence
Joseph Wright
Level 3:
  • Hyundai Master 1,729 Answers
  • Posted on Oct 13, 2016
Joseph Wright
Hyundai Master
Level 3:
Answers
1729
Questions
Helped
455403
Points
5127
A Google search netted many images and diagrams:
https://www.google.com/search?q=Hyundai+H100+2010+timing+marks&biw=1280&bih=684&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjd9c25itjPAhWF7SYKHV86Ay4QsAQIGw
5 Related Answers
Anonymous
  • 510 Answers
  • Posted on Mar 21, 2010
SOURCE: Timing marks setting Hyundai Lantra
Installation
Ensure timing marks aligned [6] & [7] . 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets. 2. Slacken tensioner pulley bolt [8] . Push tensioner pulley firmly against timing belt to tension belt. 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm. 4. Except Matrix: Turn crankshaft one turn clockwise. 5. Matrix: Turn crankshaft two turns clockwise. 6. Ensure timing marks aligned [6] . 7. Apply a load of 2 kg to belt at . Belt should deflect 4-6 mm. If not: Adjust position of tensioner pulley. 8. Install components in reverse order of removal. 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
7 is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head
6 is crank timing mark,pin mark on crank lines up with mark on block
NOTE this mark is just before top
robert kious
  • 58 Answers
  • Posted on Jan 29, 2009
SOURCE: geo metro timing diagram
woot i feel your pain i had the same problem. go to autozone.com and go to thier vehicle repair.
enter your year make and model and find it. but please hear me on this one.. be carfule thier are like 2 timing references and one timing mark. USE THE DOT. pls i learned the hard way. lol use the dot on the cam sproket. good luck
Anonymous
  • 6 Answers
  • Posted on Jun 29, 2008
SOURCE: Timing Marks location
7827889.gifYour welcome
Bill Hackett
  • 383 Answers
  • Posted on May 06, 2009
SOURCE: need timing belt mark diagram for 95 corolla 4afe
malibluert: YOUR IN LUCK! This series engine is simple and the references aren't hard to find. READY???????
IF you are just trying to reset the belt at the top and have not remover the crank pulley, bring the crank around to Top dead center on the # 1 cylinder,. It will read Zero degrees on the timing mark scale.
Up top, look at the cam gear closely You will see that there are 5 spokes which support the actual gear. Look closer and you will see that one of these spokes has a small hole in it about 3/4th of the way towards the outside of the gear. Position the gear to where that hole is at 12:00 PM. NOW, if you look thorough the hole, you should should see a small notch that the hole should be centered on. If not, move the gear until you can look through the hole and the notch falls dead center. At that point in time, you have the crank ant camshaft in perfect time with each other.
When you put the belt on, make sure that the side which is slack is the tensioner side. You should be able to slip the belt on, matching the teeth with the teeth on the gears to where one side is fairly tight and you can not roll the cam counter clockwise.
IF you are replacing the belt, you have the crank pulley off and you position the woodruff key straight up at 12:00 PM and the procedures are all the same other than that. when you set the tension. A good rule of thumb is to find the longest span of belt, and with your thumb and forefinger twist the belt. if it twists to 45 degrees toward the block, it's perfect. Any more or less, needs to be reset.
I hope my answer suffices. A picture wouldn't be any more clear.
Let me know how you did.
NOTE: This engine does NOT bend valves when a timing belt fails.
Patrick Rayome
  • 1757 Answers
  • Posted on Mar 07, 2010
SOURCE: mazda b 2500 how to set timing when the timing belt has broken in
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Timing Belt and Mark(s) Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1998/make/mazda/model/b2500/1998_mazda_b2500_timing_belt_diagram_marks.htm
I have a 2001 Hyundai accent with the 1.5 l single overhead cam I need the torque number and sequence for The rocker shafts
The torque specification for the rocker shafts on the 2001 Hyundai Accent with the 1.5L single overhead cam engine is 18-20 lb-ft. The proper torque sequence is as follows:
  1. Tighten the bolts to 8 lb-ft in a crosswise pattern.
  2. Increase the torque to 15 lb-ft, again in a crosswise pattern.
  3. Finally, tighten the bolts to the full torque of 18-20 lb-ft, again in a crosswise pattern.
Make sure to use a torque wrench and follow the sequence carefully to ensure proper tightening and prevent damage.
Hi there i have elantra 1.8 broke the cam belt. Did it bend valves. And can you plz send me the torque settings
Hyundai engines are interference engines so you will have valve damage. before you attempt to do the job get yourself a workshop manual as these engines do not have torque settings but use degrees on an angle setting for the head studs. The manual will explain the timing mark settings and all the details you will need.
How do set the timing on hyundai excel 1998
It seems you are encountering problems trying to set the timing marks in your elantra,not to worry,simply follow the stepwise solution below;
STEP 1. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut between sprockets.
STEP 2. Slacken tensioner pulley bolt [8].Push tensioner pulley firmly against timing belt to tension belt.
STEP 3. Tighten tensioner pulley bolt [8] . Tightening torque: 43-55 Nm.
STEP 4. Except Matrix: Turn crankshaft one turn clockwise.
STEP 5. Matrix: Turn crankshaft two turns clockwise.
STEP 6. Ensure timing marks aligned [6] .
STEP 7. Apply a load of 2 kg to belt at .Belt should deflect 4-6 mm. If not Adjust position of tensioner pulley.
STEP 8. Install components in reverse order of removal.
STEP 9. Tighten crankshaft pulley bolt [2] . Tightening torque: 170-180 Nm
(7) is timing mark on cam,pin mark to top,hole in spoke below pin mark lines up with mark on head (6) is crank timing mark,pin mark on crank lines up with markS on block.
Good luck.
2helpful
Installation
2002 hyundai accent DL sedan. my tension pulley
hi from uk to retime cambelt is as follows = the crank cog has a mark which lines up with corresponding mark on front of engine block mark is approx 12-30 o/clock this is TDC No 1 the the cam cog has a small drilled hole in one of the webs just below the cog teeth ? this hole has to be at 12-o/clock position and then using a small mirror if you look through this hole you will see a vertical notch on the front of block this is theTDC mark for cam you then fit belt anticlockwise from c/shaft to cam then round tensioner then release tensionor to tension belt and then lock it up torque both bolts 20 - 27Nm rotate engine manually 4 complete turns clockwise then recheck marks ok /re align ? then re assemble crank pully bolt torque is 140 -150 Nm may i just inform you? that your engine is what is known as interferance that is to say in event of c/belt failure there is more than likely valves to piston contact however this can also occure too if miss timed belt fitted and engine has tried to start ? a compression test on cylinders will confirm if this has happened or not ? hope this helps
Please help head gasket has gone on my hyundai tradjet gol gsket kit but no loosen tighten order for the head bolts and icould do with timing marks many thanks from andy
The gasket kit alone is not the answer to your problem. You don't need to worry about bolt tightening sequence, yet. Get the head off, take it to a machine shop, have it surfaced, check the valves, etc, for leaks while you have it off. Then attempt to put it back on. The tightening sequence is in the book you bought to work on the car. Then put the timing belt on, it has marks on it, the cams have marks, and the crank has marks, they all line up, If you don't see any marks on the belt, mark it before you take it off, with a white marker. Then the exhaust, intake, and air , then the water, power, alternator, ac, etc. Then you should be all set.
I need to know the timing points
hi from uk the marks i assume are the timing belt marks ?? to st up turn engine to T D C number 1 cyl fire check the cam cog and view the hole in the cg is at top and the vertical line mark on cam bearing cap are lined up along with the crank mark which should line up with the point on engine this mark is approx at 11 o clock position when viewed if not rotate engineanother rev till both marks line up release tensioner (renew it !) fit new belt from crank anticlockwise to cam then round tensioner push tensioner against belt firmly and torque 43-55 Nm turn engine by hand till marks re aligne ok ?check tension ? ok ? torque crank pully bolt 170-180 Nm reassemble engine hope this helps ?
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
