Enable/disable APN: <greyed out unless there are multiple APN's>
Bearer: Unspecified
MVNO type: None
MVNO value: <Not set>
Tap the Menu icon with three dots, then tap Save.
Tap the desired APN profile you want to use. The bullet point fills with color next to the APN profile.
Manual network selection
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
From any Home screen, tap Apps.
Tap Settings > More > Cellular networks.
Tap Network operators.
Wait while the device populates a list of available networks.
Tap the desired network you wish to register on.
Switch 2G / 4G
Tap Preferred network types.
Choose from the following options:
LTE/WCDMA/GSM (Auto mode)
WCDMA/GSM
GSM only
Turn on / off airplane mode
Airplane mode turns off wireless connections. This allows app and menu use, but prevents voice or Internet use.
From any screen, swipe down from the top of the screen.
Tap the down icon (v), the tap Airplane to turn on or off.
Turn on / off data roaming
Tap to turn Data Roaming on or off.
Turn on / off mobile data
From any Home screen, tap Apps > Settings > Data usage.
Bearer: Unspecified
MVNO type: None
Switch 2G / 4G
WCDMA/GSM
GSM only
From any Home screen, tap Apps > Settings >Data usage.
Bearer: Unspecified
MVNO type: None
Switch 2G / 4G
WCDMA/GSM
GSM only
Tap to turn Cellular data on or off.
From - https://support.t-mobile.com/docs/DOC-28547
Goto Settings > More > Mobile networks > Access point names > select the dot beside the APN.
if there are no APN's you need to create a APN(google ATT Apn) and select the dot.
The simple answer is your settings are wrong, you can go to your carrier to fix it or a local repair shop.
The setting that is likely needed to be added or changed is called "apn" which is access point network.
If you feel comfortable with changing things in your phone; Go to settings > more.. > apn (if on screen) or mobile network > apn > menu button > Add or New > The next part will depend on the carrier you are on. The link is an example of Canadian carriers apn settings. Android Coliseum Rogers Telus Bell Fido Virgin Koodo APN List
You need to set the APN settings. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names, click the menu and "New APN" Please try the settings below:
APN: http.globe.com.ph
APN Type: default
Note: No need to set the other fields while creating the new APN.
Select the newly created APN. To connect to the internet, tap on "Mobile Network". It will then connect using the newly created APN.
This works on my HTC Wildfire. Hope this helps.
or anyone wanting to know how to change their APN settings for future reference here it is:
on the keypad type *#87927# and wait until the APN setting pops up. click the APN available.
then change these settings.
name : t-mobile us 310 260 ----> name : simple APN : epc.tmobile.com ----> APN : simple proxy : not set ----> proxy : 216.155.165.050 port : not set ----> port : 8080 username <leave blank> password <leave blank> server <leave blank> mmsc <don't change> mms proxy : not set ----> mms proxy : 216.155.165.050 mms port : not set ----> mms port : 8080 mcc <don't change> mnc <don't change> apn type <don't change> authentification type <don't change>
after that just back out and give it a few minutes. as long as you have the data plan your 3g icon should show up ready to go.
