Computers & Internet Logo
A
Anonymous Posted on Dec 18, 2013
Mean median mode - Computers & Internet
Geoffrey White
Level 3:
  • Master 3,965 Answers
  • Posted on Dec 18, 2013
Geoffrey White
Master
Level 3:
Answers
3965
Questions
Helped
915046
Points
10651
Consider these numbers: 2,3,5,7,13,15,25
Mean: the arithmetic average of the number group, so 70/7 = 10
Median: that value with as many numbers on one side as on the other, so 7
Mode: the most often occurring value, so there is no mode to this group of numbers, which can occur.
What is the mean in 6 13 14 7 5 in maths
I could give you the answer but this website explains very nicely, how to calculate each type of average. The second example they use fits your list of numbers better than the first.
Mean Median Mode and Range
1helpful
Mean median mode definitions
Mean: the arithmetic average = total of values/ number of values
Median: that value with as many to one side as on the other (might be the mean of the 2 middle values)
Mode: the most often occurring value (might be more than one mode)
Mean, median, mode
Mean= average =(sum of data values)/(number of data values)
Mode is the most frequent data value.
Median: Sort the data in ascending order. The element in the middle is the median.
If the number of data is odd, there will be one MIDDLE element. It is the median.
If the number of data is even, there will be two elements in the middle. Add the values of these middle elements and divide by 2. The result will be the median. It is not part of the data.
TI-34 mean, median, mode
Math mean median mode
The mean is 10, the median is 9.8, and there is no mode.
The mean is 30, the median is 30, and the two modes are 30 and 31.
Mean, median, mode
You don't need the calculator for that. Sort the data in ascending order.
Mode
Find the most frequent data element (the one repeated the most) in the set. That is the mode. If you have several elements that share the same highest frequency all of them are modes.
Median
Count the number of elements in the set.
If the number of elements is ODD the median is the element that happens to hold the middle place in the ordered set.
If the number of data elements is EVEN, then there is not one middle element, but 2. Call them if you wish MIDLeft, and MIDRight
Take the values of these two elements and calculate their average.
Median_value =(MIDLeft+MIDRight)/2
That average is the value of the median.
You can imagine the median as a virtual (not really there) data element inserted between the two middle elements and having as value the average of the two middle elements
Your set would look like the following
{Min_value, ..., MIDLeft_value, Median_value, MIDRight_value, ..., Max_value}
Now, was there something about fractions?
Mean median mode and range
Mean: (60+60+89+90+93+94)/6 = 81
Median: Middle number, in this case between 89 and 90: 89.5
Mode: Most common number: 60
Range: Highest number minus lowest number: 94-60 = 34
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
2answers
mean: 77
median: 87
mode: none or all of them (take your choice)
range: 43
If this is homework, be sure to show your work.
Grand Canyon Tech
Grand Canyon Tech
