If you've replaced the variable speed unit in your Bosch 11318EVS SDS-max Demolition Hammer and the variable speed is still not working, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot and address the problem:
Check Wiring Connections: Ensure that all wiring connections related to the variable speed control are properly connected and secure. Loose or damaged wires can disrupt the variable speed function.
Control Switch: The control switch itself could be faulty. Test the switch to make sure it's functioning as intended. Use a multimeter to check for continuity across the switch terminals in different speed settings.
Speed Control Potentiometer: The potentiometer, which is responsible for adjusting the variable speed, could be malfunctioning. Test the potentiometer with a multimeter to ensure it's changing resistance smoothly as you adjust the speed.
Electronic Control Board: The issue could be with the electronic control board that governs the variable speed function. Inspect the board for any signs of damage, such as burnt components or solder joints.
Brushes and Carbon Motor Contacts: Worn brushes or carbon motor contacts can affect the motor's performance and, consequently, the variable speed control. Check the condition of the brushes and motor contacts and replace them if necessary.
Power Supply and Voltage: Ensure that the tool is receiving the correct power supply and voltage. Incorrect power supply can affect the tool's overall performance.
Manufacturer's Support: If you've exhausted your troubleshooting efforts and the variable speed is still not working, it's advisable to contact Bosch customer support or a professional tool technician. They can provide more specific guidance based on the model and diagnose the issue accurately.
Professional Repair: If the issue is complex or involves internal components, it might be best to seek the assistance of a professional tool repair technician who has experience with Bosch power tools.
Remember that working with power tools and electrical components carries inherent risks. If you're not comfortable or experienced with tool repairs, it's recommended to seek professional assistance to ensure safety and prevent further damage to the tool.
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
As you have high speed inernet connection setup a internet connection from your control panel in network and internet options and save new connection. YOUR old computer will be of great help as you can get all the required fields for configuring your setup of new internet connection in your new acer notebook
the variable switch had 5 connection points on it, i bridged the connection on the 2 outer points with insulated wire,pretty much to see what would happen, this worked, as this will be a router fitted to a table i will at some point remove the wire and attach a 5way rotary switch, used for guitar electrics and mount it into a electrical switch casing,
