SOURCE: Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
SOURCE: thin vertical red & green lines in upper right of 42 in sanyo lcd
More than likely your control board. Available at www.partstore.com Cost could be between $130 and $200. Not that complicated to install if you can use a screwdriver and are careful. Let me know how this works out.
hardrocko
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
SOURCE: I have a 42 inch sanyo LCD it was working fine
You may have bad T-CON board or bad connections on the ribbon cables between the T-CON and the LCD panel. You cantry reseating the cables first, but be REAL CAREFUL since it is very delciate works. T-CON: E40951307-TCON Troubleshooting 10-22-09_OPT http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
Learn more about T-CON/LCD panel failure here:
http://www.mediafire.com/?zzjygannjty PDF download
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
