My gas tank had water in it so i have dropped my tank cleaned it out replaced the fuel filter as well as the filter for the pump and there is still water coming out of the hose that runs into the throttle body.. any suggestions?
SOURCE: 1986 toyota truck 4x4, 4cyl,
The igniter interprets signals of time and position from the distributor, fits the efi ecu with information and then the ecu gets back to igniter to tell it when to fire specific cylinder, we used to have problems with the distributors and also igniters.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
SOURCE: 2001 ford e250 5.4 v8...vehicle
Are you try scanned the PCM to know if some fault codes are stored there? Are you check injectors? We recommend to de-pressurize your fuel system. Disconnect the power to your fuel pump, by either disconnecting it's power supply, or pulling the fuel pump fuse or relay. Once the fuel pump has no power, crank the engine for a few seconds. The engine might start, but should die a few seconds later. If it continues to idle, then you didn't disconnect your fuel pump.
Once the fuel system is de-pressurized, we can begin to remove various parts from the engine bay to help clear up room. On a typical system, there is a fuel feed, and fuel return. For these types of systems, you would need to disconnect both of the lines, and then disconnect the fuel pressure regulator. The fuel injectors are held in with clips that hold the harness to the injector. Remove these clips, and pop off the wiring harnesses. The fuel rail is held in with a few bolts. Remove these bolts, and then the fuel rail should be loose. Pull the fuel rail out of the intake manifold or cylinder head, and you can now easily remove the fuel injectors.
Couldn't start his but had 40 psi fuel pressure, but even though it
turned over. Are you check crankshaft, this is located crank sensor under the a/c compressor, to the left of the balancer. The camshaft sensor is in the timing cover usually behing the PS (Power Steering) fluid tank. FInally, try jumping or bypassing the fuel pump relay to test if have pressure, if this work, then go to the next device, fuel filter, then next at fuel pressure regulator and this way so on.
Keep us updated.
SOURCE: I started it up one morning, it was running fine 4
Have you checked the fuel pressure on it? Fuse? Pressure to the engine?
SOURCE: 1998 Honda Civic EX AT idle is fluctuating and the
Could have a bad catalytic converter ????
