Try taking the sim card out and put it back in...it could be network, tower or sim
related....wait at least 20 seconds before putting battery back in..this reboot should help..if not, u should contact ur service provider....
try another sim card first to verify if the problem is not your sim card.
if the next sim card is still not recognized, there is a problem with the phone. you may have to bring it to repair shop.
this problem come from your phone that did not recognized your sim card, try insert your sim card to anohter phone, if at another phone it recognized the problem come from your nokia 7610 supernova sim card slot section, change sim card slot with new one, this will solve your problem
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.superunlockcodes.com/motorola-l7-slvr/rs12wp9/
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.theunlockarena.com/motorola-l7-slvr/rs13wp9/
Remove the SIM and clean it with soft cloth. Try the SIM on any other Mobile phone. You can also try another SIM card on this mobile to make sure the phone is working properly. If another SIM card is working properly that means the SIM card you are currently using may be corrupt. Its easy to replace a SIM then replacing a phone. Clean both SIM and phone Connectors then try to insert the SIM.
Hi, To get the issue nailed, we have some recommendations to make … Try the following ; 1.)Did you ever try to clean the sim card reader or even to resolder its connectors ( if you are a mobile tech ). 2.)Chances are when you replace your current sim, you will be back up running. 3.)If it still shows this, then it more than likely locked. You can use softwae like the one the company below sells, called mototools 6. this will remove the network restriction, and unlock the phone : http://www.motounlockuk.co.uk
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
you can import your contact from your sim to the phone. and vica versa the phone wants a sim card to function, the only way to bypass that is to have the phone unlocked. You can purchase a code pretty cheap around the net.
I 've got motorola W375 for present over from AU and when I inserted my sim card in, first ? is insert subsidy password which i don't have ( vodofone office too) how can i find and use my new mob. ph.?TA
Hi, Can you see any damage to your sim reader pins, located under the sim.?
