Mag Innovision M572TVs LCD Television Logo
N
Nikolis Nikolaisen Posted on Dec 10, 2013
Mag 3200 Rx-326 schematic - Mag Innovision M572TVs LCD Television
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Mag model 3200 wont turn on
Check the power cord or fuses or the power supply Module
Mag 3200 tv manual
There are plenty of free operation manual downloads. Please search in Google.
MAG Model 3200 HDMI Not working
The HDMI socket could have a dry joint or loose connection on the board, as these are usually prone to wearing out.
Digital programming
The RX-326 does not have a digital tuner, only an analog.
Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Mag Rims
The answer is no. You could try with tire dimension 30, but I highly discourage you to do so.
Adding 20" rims will significantly reduce the driving quality of your car. Stick to the original 18" rims and you will be fine. Do not put the looks above the driving quality of your RX-8, because the driving quality is what your RX-8 is all about.
Here are some reasons not to do it:
1. Your car will crawl... Acceleration is much worse.
2. It will immensely increase the wear of your shock absorbers.
3. It will give you real hard rides you will have neck and back problems.
4. Cornering will be really dangerous instead of fun.
5. The tires will be much more expensive.
Hope this helps.
16helpful
9answers
Proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Top Mag Innovision Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Mag Innovision Televison and Video Expert? Answer questions, earn points and help others
