Cars & Trucks Logo
k
khalid khalil Posted on Dec 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Golf sdi 99 gear manual oil
I want to know what kind of gear oil is compatible with my golf sdi 99 car
Wine Country Autoworks
Level 2:
New Friend:
  • Expert 78 Answers
  • Posted on Dec 04, 2013
Expert
Level 2:
New Friend:
Answers
78
Questions
0
Helped
17599
Points
194
Since you say gear oil I assume that it is a manual transmission. Here are codes and fluid type/capacity
Transmission fluid Capacity 2.0 liters
Transmission code: DYP, ECW, EFG, ERS, FBV, FBX, FBY, EGY, EVR, EZK, FCF Type G51 SAE 75w-90 (synthetic oil)
Transmission codes: DQY, DBZ, DZQ, DZC, EGC, EGF, EKG, EMR, EMS, ENH, ENJ, EBJ, EBP, EBQ, EZH, EWW, FBW, EGR, EBN, EGT, EGX, EGU, EHC, FDS, EHA Type G50 SAE 75w-90 (synthetic oil)
5 Related Answers
A
Anonymous
  • Posted on Oct 25, 2008
SOURCE: brakes
You need to get hold of a wind back tool. The pistons screw into the caliper and can be very stiff. Hahnes manual says you can use pliers but I've had no joy using that method!
Anonymous
  • 59 Answers
  • Posted on Dec 22, 2008
SOURCE: what weight gear oil do i need 99 chevy Z71
I believe that it is 80w90 but you also have to add differential additive for locker that is inside. you can purchase additive at chevy dealership, napa, or other parts stores just make sure it is formulated for gm.
Kevin Rahme
  • 401 Answers
  • Posted on Jun 14, 2009
SOURCE: Epic 2005 auto gear car which oil to be use for GEAR
Automatic Transaxle Fluid (GM part no. 89021903)
Anonymous
  • Posted on Mar 02, 2010
SOURCE: I have a vw golf mk 5 2.0 sdi, when engin starts,
Check the VAG code. I had the same problem with my MK V 1.4 FSI. Let me guess when you rev it, it dusnt shake anymore?
It might be one of your cylinders are misfiring. And this might be faults with spark plugs, coil pack or the injector. You'll be lucky if it is the first two as they aren't much expensive to repair. It will cost you if it is the injectors.
Anonymous
  • 208 Answers
  • Posted on Nov 29, 2010
SOURCE: temperature light in red is flashing
Change the temperature senzor. You need to put in the samo colour as your's. Thera are aouple of different colours.
Paint code for vw golf sdi mk5 54 plate
On the boot floor or in the front of the service record you will find a data sticker the paint code is on that sticker.
Misfire golf 5 2 0 sdi
put in some iridium spark plugs and change oil and filter
2004 VW golf 2.0 SDI manual. I turn engine on and
I would get a diagnostic check done on it as could be a number of things, is your engine management light on or does it come on at any point.
2005 volkwagen golf 2.0 sdi [ac] 5 doors hatchback manual handbook
Here is a place where you can get the manual: http://www.alldatadiy.com/ Just plug in the information for your car, and checkout.
Why wont my mk4 vw golf go into 3rd 4th and 5th gear, but will go into 1st 2nd and reverse?
hiya all can any1 help ive had a new master cylinder and slave because the car would not go into gear. problem not solved. took the clutch apart foubd out that the pressure plate is pused out with a long steel rod and it pushed out the nipple part in the middle of it. same happend with the new 1 it was only in there for 3 weeks what would cause that to happen again carnt figure it out any ideas guys vw golf t reg mk4 sdi 1.9
1helpful
2answers
Golf mk4 sdi brake light problem??
What colour is this light.
The Golf mk4 sdi certainly should have brake pad wear sensors front and rear and the light on dash for this is orange with a similar symbol to what you describe.
The ABS light is orange with ABS printed on it
John
Brakes
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
