Cars & Trucks Logo
Karen Giordano Posted on Dec 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Replaced the battery in my car (2006 CR-V) now the prostart works, all functions but will not start remotely .
Dave Jansen
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Dec 04, 2013
Dave Jansen
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
16782
Points
171
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Just had prostart installed on 2002 Dodge Gr Caravan.Replaced battery and now, remote start turns ignition on and cranks but will not start. Makes 3 attempts, shuts down. Door locks don't work either.
One would hope that the shop that installed your remote starter would stand behind their work and correct this problem. Your other options are to troubleshoot and correct yourself, or take it to a qualified shop to troubleshoot and correct. Then take that bill to the shop that installed the remote starter for reimbursement.
I have to install a remote starter ProStart 3271 ct J need to chima Electric to complete installation I need to connect the wire starter kill output
talk to prostart on custom car hacks.
only th
ey can help., after all its THEIR design.
when stuck far from home , dont expect some pro to figure out your custom wiring , for cheap, for fast or even possible.
dont hack cars! and save tons of grief and cash,,,,
unless its a toy. then hack away.
looks like you are already in trouble. sure.
(done many)
I have prostart 3 way new installed into 1995 f250diesel can't get remotes to conect to the prostart brain box
Verify batteries are installed and installed correctly in the remotes. Examine the batteries and the battery holders on the remotes for "shipping isolators", pieces of plastic film or tape that insulate the batteries from the battery contact points. Verify the batteries are fully charged with a volt meter. Beyond these basic check points, contact prostart support.
Pontiac mini van 1998 transport, V6, 3.5L I left lights on and when I came back found my car battery died, I get boosted, since then my prostart two way 3 in 1 remote starter never work. Last winter I...
you will have to unhook your prostarter or get someone to replace its burnt from charge then after pro start is unhooked then put battery back in the turn key over.
3helpful
2answers
No start cranks but does not fire has spark. has fuel if bypassed by relay fuses good new fuel pump a year ago has fuel replaced battery froze, has prostart remote start, been in 8 years no issues 2000...
check to see if the security light or anti theft light flashes. if that is the case, sounds like the bypass for the remote starter may be causeing the no start by tripping the anti theft system. Remove remote starter and bypass system and join any cut wires back together that may be cut for remote starter. Try starting, if theft light still flashes leave key in the on position after attempted start for 15 minutes till theft light goes solid, turn off and try again. Repeat process for three times to re-learn factory theft system in vehicle. If problem still persists, then take to your local dealer to reprogram factory theft module in the cluster.
1helpful
What brand remote car starter?
Prostart models work great with Dodge makes, they are made by Directed Electronics and are available at Canadian Tire, you will also require a bypass moduel PKUMUX
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
