Craig CMP168C  MP3 Player Logo
Posted on May 10, 2009
My computer wont register that my Craig mp3 player is connected so I cant put music on it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
582
Points
I HAVE LOST THE INSTRUCTIONS AND MY COMPUTER DOES NOT HAVE CRAIG AS A TYPE OF MP4
My device wont play all of my music
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
I cant get my craig mp3 player model number cmp648f to turn on
aktsane i can't understand when is it charging... when i just connect it to my PC or i need to eject it? when i first connect it to my computer it seems to be in transfer mose, but when i click eject, it starts charging but then stops cause it's full... i waited for it for 10 hours but still not working :((
How can I save what I Recorded on my Mp3 to my computer?
how can i download music to my Craig 2GB MP4 Player?
1helpful
My 8gb mozaIC WILL NOT REGISTER WITH MY COMOP
Support for Zen Mozaic on the site of Creative:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
1. Firmware [for your player]
Get a download from the support site and install:
this will put maps onto the device. Communication with the software
on the computer is available after getting the next item (2.) is done.
2. Application software [for the computer]
2.1 Creative Centrale (+ User Guide) is usefull to get songs on your Mozaic.
2.2 Windows Media Player 11 can be used as well. Note: You'll first have to make a playlist: Save the playlist: Next Synchronize it onto
the Zen.
3. Drag and drop
Once firmware is installed you can also use the drag and drop method. Move music, pictures, video inside maps on the computer into the corresponding map onto the player.
Don't hesitate to post a comment
when this will not get your Zen to play.
2answers
How to put music on the player, wont connect to computer some reason
first of all, it depends on what mp3 player it is. but there is an obvious first step to ANY of them.
1) do you have it connected to the computer via usb?
Now that we are past the obvious, Here are a couple various solutions based on type of mp3 player it could be:
IPOD:
1) Download Itunes from www.apple.com
2) Install Itunes onto your computer.
3) Once it is installed, connect your Ipod to the computer, and it should register in itunes. Here, you can click on it, and go to your music.
4) Open a separate window with your music folder, and drag files from that window, to the Music area of Itunes. This is easy.
5) when you have all the music you want on your Ipod in the music list, press "synch". It will all go onto your ipod. and
Voila! you have music!!
Sansa:
1) forget rhapsody. its ****, ignore it, ditch it, it will charge you, and you cant even make playlists with it!!!
2) Open Windows Media Player
3) Open your music folder in a separate window
4) Drag and drop songs you want into a windows media player playlist.
5) Synch playlist to sansa.
OR
1) Still forget about rhapsody, it sucks.
2) Go to My Computer
3) Click on Removable Storage device (you should already have it plugged in at this point. the removable storage is said mp3 player)
4) Open a separate window with your music in it.
5) Drag and drop music files from your music folder into the removable storage disk. you wont be able to make playlists this way, but its easier.
Now almost any other mp3 player would work with one of these methods, possibly only with deviance in which program you will use. I hope this was of use to you.
2helpful
Can't see downloaded music files on Craig 2GB Digital MP3 player
Going by what instructions say can be a real headache huh... here's a way around all that too legit stuff... your craig should show up in my computer as a removable disk... right click on it and go to explore to view all the thing on the player... now minimize the window for the time being.... if you rip your CDs correctly and play in windows media player.. then they should be listed under-- My Documents/My music.... keep that window open for the time being and find the music you want on your player... go back to the window of the removable disk and find where all your music is stored in it.... now with these two windows side by side... drag and drop the music in your music folder into your Craig (removable disk) folder... you should see a window open saying copying with an ETA.... after your done putting your music in check and see if everything worked out okay... and if ya need anymore help don't hesistate to ask... good lick////peace
Craig MP3 player
connect it to computer using cable available with it
then you can transfer all files
3answers
Craig mp3 player
u have to plug the usb cord into the computer with the computer on an then it has to be in the mp3 screen then it charges
Top Craig Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert
ADMIN Andrew
ADMIN Andrew
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
