I uninstall ask. Then in Internet Explorer turn off all addons. Then i never use IE again unless it is to turn off all addons again. Then i go to settings in firefox or opera and turn off ask in prefered search engines. Then i go to program files and delete the ask folder. (In Vista/Win7/Win8) Then Windows Explorer/Organized/Folder And Search Options/ checkmark Show hidden files folders or drives also uncheck hide protected operating system files. under C:Program Data delete ask Under Administrator or possibly your account name /Appdata/Roaming look for ask and delete if it is there also /Local Low or /Local Remove ask if you see it This should be enough if it exists in the register windows can handle it or use a registry cleaner.
SOURCE: Homepage changes from Google.com to Google.com/es
Have you tryed this? open "Internet Explorer" click on "tools" then click on "Internet Options" at the bottom. In the field under "Home page" type in http://www.google.com click apply at bottom then ok see if this works for you.
SOURCE: I uninstalled Tatoodle from Programs (on Contriol
I'm sorry but you have unfortunately been picked at random by a secret organization that doesn't exist to endure a lifetime with Tatoodle. No more Google. However I don't exist neither so I'll help you."-}
For Firefox Web Browser:
Microsoft Internet Explorer:
This should take care of the issue. However you will most likely be under surveillance .......forever and ever...
If you need any thing clarified or more importantly if this doesn't work please let me know. Because it's most likely caused by Malware.
SOURCE: I have ask.com as my
go to google.com on the search engine, on the search page it should show a gmail sign up & to the left of the page it should show make google your homepage, just follow the prompts
you can even put a icon on your desktop of google,,when your on your google home page--right click the google name & go to create shortcut, & it should put a shortcut to igoogle on your desktop,,that's what I did
to check to see if igoogle is your home page do the following steps
Go to the start menu
Then to control panel
Network & internet connections
Go to OR PICK A CONTROL PANEL ICON
Click on internet options
The menu should show--internet properties
In the general tab at the top should be home page
Check to see if google is there for home page
If it's not type it in--igoogle & click apply & ok
SOURCE: i want to remove ask.com from my homepage and make
You need to provide the operating system and the browser information. There is usually an Internet Options control panel somewhere in the operating system. It usually has the option to enter the address of a new home page on the top layer of the menus in the control panel, then it gives you the option to apply the change.
SOURCE: set google as homepage
Very easy to answer. I assume that you are using internet explorer as your browser. If so you simply go to the tools pull-down menu, then choose the last litem on the menu which is internet options, after this the first item is to set your homepage. Either go to google.com and enter "use current" or type google.com in the box provided. Thant's it.
