change the position of the earth strap at the front of the unit
there should be two terminals one marked - and one +
normal gas welding is -, gas less welding is +
wiring diagram will be found in pulsar manual, that you got from Vehicle. then if you dont have that one, Xbhp is a website that will have pulsar manual. try check it out!
It sounds like the feed spool is too loose or worn out.There should be a tension adjustment. What wire size are you using? On those off brands they usually use .035. and make sure the spool is not dragging. The wire spool also has a tensioner, or should have, in the center. Good luck.
