I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles 2. Select Profile and then Select General. 3. After selecting General you will be given 3 options (Activate, Personalize, Timed) 4. Select Personalize. 5. In the Incoming Call Alert field, select Ringing. 6. In the Ringing Tone field, select your favorite ring tone. 7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max. 8. Scroll down to the Vibrating Alert field and set it to Off. 9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field. 10. Save your modifications. 11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption. In that case reset your phone to the factory default settings by going to: Menu > Settings > Press UP button. Select Restore Factory Sett. give your Security Code (default = 12345) and viola. (Make backup of your messages ad contacts before attempting this)
Settings In this menu, you can adjust various phone settings. To reset some menu settings to their default values, select Restore factory set. Tone settings Select Menu > Settings > Tone settings and from the available options: Ringing tone-To set the tone for incoming calls Ringing volume-To set the volume level for the ringing and message alert tones. If you set Ringing volume to be level 2 or above, your phone rings with the ringing volume ascending from level 1 to the level you have set when there is an incoming call. Vibrating alert-To set the phone to vibrate when you receive a call or a text message Message alert tone-To set the tone to sound when you receive a text message Warning tones-To set the phone to sound tones, for example, when the battery is running out of power
Open menu and select tones see if the ringer settings are in place, if not set the tone and volume and set ******** to on.
If this does not bring in the ringing,then opne menu, setttings, restore to factory settings-- type 12345.
the set will go to factory settings.
If not remove batter and reinsert after about 10 minutes.If there is no result then the phone hardware can be faulty.
separate alarm you may use the calendar to do list to set alarm times for each scheduled tasks you want. and if you just want your phone to just vibrate and not ring then costumize your profile put your incoming call alert to off then on you vibrate and thats it!
menu 2 settings 3 tones incoming call alert (set to ringing) ringing tone ( pick your ring tone) ringing volume (set to level 5 loudest) vibrating alert (on) message alert tone (pick tone) instant message alert tone (standard) keypad tones (on) warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok alert for (all calls)
let me sole it by steps do it step wise press 1. menu 2. profiles 3. general 4. personalize then move down to incoming call alert than select off and move vibration select on
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
Follow this steps in the given order - 1) Switch off your phone 2) Remove memory card 3) Switch on your phone 4) Ask a friend to send you a message. Now you will hear the tone 5) Switch off, insert the memory card & switch on again 6) Ask someone to send a message again. It will work
