Squeaking fan belt
fan belts squeak for several reasons 1 incorrect belt for pulley.2 belt running on the botton of the pulley and worn pulleys. To check measure across the top part of the pulley and the widest part (back) of the belt should be the same if not marginally bigger. V belts work best at t5he top of the pulley.If you can see that the pulley is polished at the bottom the belt is slipping and not driving Check if the pulley sides where the belt runs is not stepped from wear. Recheck the tension as new belts stretch slightly. If you have a multi groove pulley check the tension setting. As a last resort CRC make a product that is used to stop belt but it is best to fix the real fault first
