Computers & Internet Logo
Anonymous Posted on Apr 29, 2009
Hello sir, my system has been conducted a problem. lan card is disable so . i donot know how to enable lan card please give me a solution. thanking you
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Apr 29, 2009
Anonymous
Expert
Level 2:
Answers
90
Questions
0
Helped
32004
Points
220
If the lan card is disabled then you have to reseat the lan card if that is a external lan card connected & not the integrated one..also check for the network adapters if they are installed under device manager or not...in case not you also have to install network adapters...
9helpful
5answers
My facebook has been disabled i dont know why .. i didnt do any thing bad on it and iam sure that no one reported me . i bought chips from zynga poker with my visa card from about 24 hours ago and from...
Please review Facebook's community standards to learn more about specific types of conduct and content that are not permitted on the site.
If you believe your account was disabled by mistake, please follow the directions outlined here and Facebook will review your situation further.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
1helpful
4answers
My ports and my on board LAN are not working my motherboard is ECS PV4MM2..What shoulbe the proble and how can I resolve it.Yahks if you would respond immediately on my problem
Go to Device manager By following this steps
  1. On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
  2. In the System Properties window click the Hardware tab.
  3. In the Hardware tab click the Device Manager button.
Then on left side Search for Yellow question mark on Ethernet controller if it occurs than the problem is that you have to reinstall your LAN drivers which can be Downloaded here
And If there is no Yellow Question Mark then you have to bring a LAN card and insert in PCI Express Slot.
1helpful
2answers
ASUS P5KPL-AM SE Motherboard no land card
Make sure you have it Enabled in the Bios (from page 2-17 of the user manual):
2.4.5 Onboard Devices Configuration
Onboard PCIE 10/100M LAN [Enabled]
Allows you to enable or disable the onboard LAN controller.
Configuration options: [Enabled] [Disabled]
LAN Option ROM [Disabled]
Allows you to enable or disable the boot ROM in the onboard LAN controller. This item
appears only when the Onboard LAN item is set to Enabled. Configuration options:
[Disabled] [Enabled]
Cannot connect wireless why
You have to elaborate sir, can it detect wireless networks or not? if the computer can no longer detect wireless network then it could be that the wireless switch is disabled so to enable it,normally we press Fn+F5 which is the universal code to enable/disable wireless devices whether bluetooth or wireless LAN card..
2answers
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
1helpful
3answers
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
2answers
INTEL ATOM D945GCLF ( LAN not working)
when you give power to computer press F2 or F1 or "del" key then enter in bios .
Then go to advanced configuration then check your lan port is disable? if it then enable it.
then check.
If it is in warrenty then take it to service shop they repalced it if it has hardware lan chip has issue.
Dell Inspiron 5100
You can try checking the BIOS first see if its disabled in the BIOS to boot to the BIOS turn on your computer Press bios2.jpg during POST to enter the system setup program.
once in the BIOS you might have a multi page view, or a one page view, look for the INTEGRATED NIC see if its enabled or disabled. just enable it and restart the system then:
download
LAN CARD DRIVER
http://ftp.us.dell.com/network/R54631.EXE
see if it works. hit me back with the result.
With lan card
please restart your system and at the blue dell logo keep tapping the F2 key, the bios setup screen will open, check in here if the lan card is enabled here or not. if not enable the lan card, once it is enabled from here windows will detect it and prompt you to install drivers.
Further Queries are welcome
If you find my solutions helpfull please do rate me
2helpful
Soud driver software downloading
software for sound driver and LAN driver
Grand Canyon Tech
Grand Canyon Tech
