When typing the spacebar either won't work or it types continuous spaces without being pressed
There is something under the space bar you can pry it up carefully and remove the debris it should snap right back in.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Space bar on Latitude D-600 Dell is sticking
There may be something under the spacebar key preventing its contact with the base. If you gently pull up the key it will come off and you can check.
It's a bit tricky to put it back on, gently push it back on rocking it from top to bottom.
Failing this, you can buy a new keyboard quite cheaply on the web.
SOURCE: Acer Aspire 7720 Notebook Keyboard Problem
Yes there is a fix for this issue. Try the following
1. Open control panel
2. Click on "MOUSE"
3. Click on "POINTER OPTIONS"
4. Uncheck "HIDE POINTER WHILE TYPING"
5. Click Apply
5. Click "OK"
SOURCE: left side space bar does not work
The space bar on any PC is a single button you may need to make sure your keyboard is clear of any debris If that doesn't fix issue you will probably need to replace keyboard which is very easy to do. [email protected]
SOURCE: Slow Keypad with sticking space bar
My MOM Used AOL mail, for her it was the AOL news pictures loading every few seconds in the backround. If you press the pause button in between the left and right arrow boxes in the news box (under the pictures) you will turn off that function, which should speed up your typing, as every time a news item switches it causes a delay which may miss a keystroke, etc.
SOURCE: keyboard space bar
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
