a foot controller is a simple speed controller
Any generic make that has the same specifications will do the job
Have you done a proper continuity check on the lead as it indicates broken wires in the cord
it could be pedal control or the speed control unit on the motor as it is reasonably common for that machine
take it in for a service to ensure that other factors ( thread around bobbin shaft, fluff etc is not slowing the machine
According to the manual, there is no speed control on your machine. It is apparently built into the foot control unit. I suspect something is haywire with the foot controller but would suggest taking the machine and foot control unit to a sewing repair service.
motor inside the casing you have to remove the cover motor at the rear beside the handwheel of sewing machine loosen set screw or lift upside machine bed so you can see the motor and wiring circuit,if bottom cover is present loosen bolt remove cover you can check motor wiring using multitester setting to R10 set switch on and setting test probe red and black rod attaching the two terminal of male plug start pedal switch besure it was unplug on ac source if there resistance on the circuit and the motor.If negative result.Isolate checking the electrical circuit.check continuity of switch,if ok.check armature winding of the motor in two terminal of the motor, you have to pull out motor inside the casing first remove belt from the motor and handwheel.Loosen the 3 bolt from motor holder to the casing.In motor assymble unlock and pull out two carbon brush attaching tha armature brush replaced a new one pair of carbob brush and install back again.besure winding was not
burn out otherwise you to replaced the motor.
