Sounds like the remote or the receiver may be faulty. The speaker icon with the zero means simply that the volume is turned down to zero.
When you press remote buttons, do you see a flashing light on the screen at all? Can you use the buttons on the screen itself to try and adjust the volume? You'd need to try these things first, so we know how to help you further.
The Laptop has 3 Ports on the
side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the
Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone
- into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers
One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it
Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone
sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select
manage audio devices then recording you should see a microphone right click
select enable windows 7
and sound then select manage audio devices then recording you should see a
microphone right click select configure
speech recognition then
you will see earphones with a speaker among a list set
up a microphone headset with microphone
then next and next again you
should see your earphones with microphone being configured
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list
make sure you have the right
one selected and in the volume box make sure the microphone box has a tick in
it or
select the voice tab
make sure that you have the
right media selected also
select volume make sure the
box for microphone has a tick in it
or you might have to depending
on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as
default
select that!!
then when you disconnect your
headphones it automatically switches to the speakers and when you plug them
back in it automatically will switch to headphones
Hope this helps.
The Laptop has 3 Ports on the side- Pink,Green,Black
Green Port is LineIn for the Microphone jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
or you might have to depending on your operating system
click on Sound
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
I have taken it back to Curry's, looks like there is a software error
